Visitor jlhx
How to use OpenCV on a Kintex 7?
I want to do image processing on a Kintex 7 and Vivado HLS supports a subset of OpenCV functions which I want to use.
My problem is that all explanations in the User Guide (UG902) and the detailed explanation in the OpenCV Application Note (XAPP1167) all refer to a situation where a Zynq is used and the conversion to the data format all HLS-OpenCV functions expect is done via the the AXI-Transfer from the ARM-core to the FPGA fabric.
Is it possible to convert a 2D-Image stored in a custom data format (like uint8/0 with 1 channel) in a dual-port RAM into the required data-format "hls::Mat"? It doesn't seem that way, but XAPP1167 states under "Limitations" that "A second limitation is that the hls::Mat<> datatype used to model images is internally defined as a stream of pixels, using the hls::stream<> datatype, rather than as an array of pixels in external memory. " which makes me hopeful that a conversion is possible. Converting back should would be required as well.
Is this possible?
Tags (3)
Participant valato
Re: How to use OpenCV on a Kintex 7?
You just have to create stream from data stored in RAM. Something like this:
typedef ap_axiu<8, 1, 1, 1> axi_video_packet;
typedef hls::stream<axi_video_packet> axi_video_stream; void read(unsigned char input[M][N], axi_video_stream & output) {   for (int y = 0; y < M; y++)   for (int x = 0; x < N; x++)   { #pragma HLS LOOP_FLATTEN off
#pragma HLS LOOP_TRIPCOUNT max=10
#pragma HLS PIPELINE II=1     axi_video_packet packet;     packet.data = input[y][x];     packet.user = (x == 0 && y == 0)?1:0;     packet.last = (x == N - 1)?1:0;     packet.keep = -1;     output << packet;   } }
And after that you can go with hls::AXIvideo2Mat. Oposite direction is quite similar and easier since you just read packets and you don't care about TUSER and TLAST signal if your input is previously synchronized to TUSER and has appropriate size.
----- Please mark the post as an answer "Accept as solution" in case it helped to solve your problem. Give kudos in case the post guided you to the solution.
Scholar austin
https://www.xilinx.com/support/.../xilinx2017_1/ug1233-xilinx-opencv-user-guide.pdf
(just google xilinx ug1223)
Does not look like we support OpenCV on Kintex (pretty much requires the processors).
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar u4223374
@jlhx Yes! HLS provides a function called hls::AXIvideo2Mat which converts a regular hls::stream to a hls::Mat type (and a corresponding hls::Mat2AXIvideo which does the reverse).
All you need to do is get your image into an appropriate format - an AXI stream of the right width, with a single TUSER bit set at the first pixel of the frame, and a TLAST bit set on the last pixel of every line. If the image is in off-chip RAM (as it usually is, because images tend to be much larger than can be easily stored in block RAM) then the Xilinx VDMA block will read data from RAM and convert it to the correct AXI Stream format.
With regards to @austin's post: that was meant to be UG1233, not UG1223. True OpenCV is not supported on the FPGA (unless you want to recompile it for MicroBlaze), but it sounds like what you need is just the hls::CV side of things (ie hardware-friendly functions that do not rely on CPU involvement). As above, this is definitely achievable.
Visitor jlhx
Thanks for your reply u4223374!
And you're correct, I only want access to the subset of OpenCV/"video function" functionality described in UG 902, Chapter 2, "HLS Video Library" section.
Regarding your data type conversion description, do you know of any official Xilinx guideline, tutorial, example or anything else?
Scholar u4223374
@jlhx The best I'm aware of is XAPP1167. It's designed more for Zynq (again), but if you just cut out the CPU-specific bits the rest is very relevant.
Participant valato
Visitor jlhx
Thanks for your reply valato! I'll try this.
