Image processing on Vivado HLS
Hi, Anyone have any code of Vivado HLS video processing. I am new in this field, I have not get any example for video using Vivado HLS. If anyone have please share
回复: Image processing on Vivado HLS
Hi paulsujoy68@gmail.com
    Refer to the UG1233, Getting started with HLS chapter is a good start point for you.
    If you want to hand on the latest Vitis tool, refer to this gitpage. Here are the examples.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
I have created really basic examples as part of my video series which are showing how to handle video with HLS:
Video Beginner Series 14: Creating a Pattern Generator using HLS (Part 1)
Video Beginner Series 15: Creating a Pattern Generator using HLS (Part 2)
Video Beginner Series 17: Create a Video Crop IP using HLS (part 1)
Video Beginner Series 18: Create a Video Crop IP using HLS (part 2)
However, I am not doing any processing on the video data
Florent
