Visitor hellotunisia
Import Dlib library cpp
I'm trying to use the cpp dlib library in vivado HLS 2019.1.
I've put all the files of the library in the project folder, and added it to the include path.
But the build fails because of name collisions (such as dlib/string.h and string.h from the standard library).
Any solutions to this problem ?
Thank you !
Re: Import Dlib library cpp
Hi @hellotunisia
Can you post you log file and include the exact error you are getting?
What OS are you using?
Aoife
Hello @aoifem,
Thanks for your answer.
I'm using Ubuntu 18.04.3.
The log file :
https://drive.google.com/file/d/1jMIhRclUscER8TlQXgH6wHT21ycONLHe/view?usp=sharing
Hi @hellotunisia
I would like to first rule out any issues in the steps you followed to add the library, so please follow the guidence in the post below for including external libraries.
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/How-to-include-external-libraries-in-Vivado-HLS/m-p/316705
Please let me know if that doesn't help and we can start looking into other possible causes of the problem.
Aoife
Hi @aoifem,
Yes the headers exist in the local directory, so they are automatically found and included.
Hi @hellotunisia
Can you include all the steps you followed to add the libraries?
When looking at your log file, it seems that you have compliation errors. Can you double check there are no errors in your code?
ERROR: [HLS 200-70] Compilation errors found: In file included from master-pynq/get.cpp:1:
In file included from master-pynq/dlib/image_processing/frontal_face_detector.h:7:
In file included from master-pynq/dlib/image_processing/../image_processing/object_detector.h:7:
In file included from master-pynq/dlib/image_processing/../geometry.h:6:
In file included from master-pynq/dlib/image_processing/../geometry/rectangle.h:11:
master-pynq/dlib/image_processing/../geometry/vector.h:1284:28: warning: C++11 requires lambda with omitted result type to consist of a single return statement [-Wlambda-extensions]
auto orientation = [&](size_t i)
I also did not see any name collision errors in the log file? Why do you think name collisions are the issue?
Aoife
Yes i was mistaken, i thought the compilation errors were due to name collision but that's the case.
The compilation errors occur in the dlib library files and in some of other predefined libraries files so it's not my code.
I think this is due to some incompatibilites with the compiler and i couldn't find a solution to solve this issue.
Redargs
Hi @hellotunisia
Can I just clarify that the predefined library files you are referring to are 3rd party libraries?
Because we can't guarantee compatibility with every 3rd party library, Xilinx has release it's own libraries for HLS. The libraries that are provided with HLS are listed in UG902:
There are also some machine learning libraries available on our Github, such as the CHaiDNN library, which you might be able to use instead of the Dlib library. If you are sure it is a compiler compatibility issue with the library, and not a compilation issue, my advice would be to use a library released by Xilinx as it has been tested with the tools.
If you need to use the specific 3rd party libraries you are currently using, Xilinx will not be able to support you debug this, but you may still be able to get help from the community.
I hope that helps.
Aoife
