sims
Newb trying to get streams to work
I'm a software developer trying to figure out how to use FPGA's via PYNQ. I have very little knowledge about actual hardware configuration, as I'm part of a project trying to figure out if PYNQ can enable Data Scientists to accelerate their functions with FPGA's.
I am therefore trying to make a custom overlay which handles streams. To do this, I am trying to mimic the methods of this research paper.
https://www.researchgate.net/publication/337030249_PYNQ-Torch_a_framework_to_develop_PyTorch_accelerators_on_the_PYNQ_platform
Thus, I have ended up with below code in HLS, which I have synthesized and exported the RTL.
However, when I try to connect my output to the DMA S_AXIS_S2MM port, it cannot connect:
Would anyone be able to assist with this? It would be much appreciated.
randyh
I recreated your example, and was able to manually connect the output_r to S_AXIS_S2MM. Are you able to do that?
Here is some additional information related to the AXIS interface:
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/managing_interface_synthesis.html#doq1539734222381
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/hls_stream_library.html#mes1539734221433
sims
Unfortunately, I am not able to manually connect the output_r to S_AXIS_S2MM, it shows only M_AXIS_MMS2 as a viable interface.
I will try to read the documentation you sent, to see if there's anything which might help me.
randyh
It looks like your output port is getting generated as an input, though I am not sure why. What version are you working with?
