Problem with AXI stream interface HLS
I am trying to create an AXI stream packet generator IP in vivado HLS. For this I need to change the AXI stream datawidth to 128 from the default 32.
I found the following solution on the internet help forums :
#include "ap_axi_sdata.h"
#include "hls_stream.h"
typedef ap_axiu<128,1,1,1> AXI_VALUE;
But HLS is giving me a syntax error on the typedef line. Can someone tell me where I am going wrong and what must be done to correct this?
Advisor
Advisor
What is the exact error? Is this in a .cpp file or a .c one?
