bdiouiska
Problems with HLS Vivado Run C simulation
Hello I am an engineer student and currently I am doing my final studies project , but i encounter some problems using vivado HLS , I hope that you can help me and thanks ,
I am going to show you my algorithm by the end of the message,
First my first problem is after i add file in Top Function (my main C file), the next step is Test bench files , I don't know what to put ??? I only have one algorithm, And this makes the Run C simulation not going in fact i got this message "cannot build design unless a test bunch with function main() is defined"
I tried to put my algorithm in both (top function same in test bench files) but i encounter some problems . My final goal is do verification synthesis and finally optimisation . I thank you for your help.
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <math.h>
#include <string.h>
int main()
int n1,n2,n3,i,j,k;
    float nu,a,b;
    a=0.25;
    b=0.5;
    nu=0.6; //donnée
    scanf("%i",&n1);
        scanf("%i",&n2);
    scanf("%i",&n3);
     float X[n1],W[n1][n2],W1[n2][n3],E[n2],Y[n2],E1[n3],Y1[n3],Deltaj[n2],Deltak[n3],Sd[n3],es[n3],Wa[n1][n2],Wa1[n2][n3];
for (i=0;i<n1;i++){
    scanf("%f",&X[i]);
for (i=0;i<n3;i++){
    scanf("%f",&Sd[i]);
// ici j'ai pas su comment calculer es[k] qui est egale es[k] = Sd[k]-Sc[k]; Sc[k] commont la calculer ??
for (i=0;i<n3;i++){
    scanf("%f",&es[i]);
for (i=0;i<n1;i++){
    for (j=0;j<n2;j++){
            W[i][j]= (rand()) / (RAND_MAX + 1.0);
for (i=0;i<n2;i++){
    for (j=0;j<n3;j++){
            W1[i][j]= (rand()) / (RAND_MAX + 1.0);
 float Somme1 (int n1,int i,int j,float X[n1],float W[n1][n2])
int h;
float Somme=0;
for (h=i;h<n1;h++)
Somme += (X[h]*W[h][j]);
return (Somme);
float Somme2 (int n3,int j , float es[n3] , float W1[n2][n3])
int h;
float Somme=0;
for (h=0 ; h<n3;h++)
Somme += es[h]*W1[j][h];
return(Somme);
//Fonction globale(1)
for (j=0;j<n2;j++)
for (i=0;i<n1;i++)
E[j]=Somme1(n1,i,j,X,W);
Y[j]=b+a*E[j];
Deltaj[j]=Y[j]*(1-Y[j])*Somme2(n3,j,es,W1);
Wa[i][j]=W[i][j]+nu*Deltaj[j]*X[i];
// Fonction 2
for (k=0;k<n3;k++)
for (j=0;j<n2;j++)
E1[k]=Somme1(n2,j,k,Y,W1);
Y1[k]=b+a*E1[k];
Deltak[k]=Y1[k]*(1-Y1[k])*(Sd[k]-Y1[k]);
Wa1[j][k]=W1[j][k]+nu*Deltaj[j]*Y1[k];
return 0;
pedro_uno
Advisor
Advisor
I think you want to separate your so-called testbench program and your function to synthesize into two different files. Your testbench contains a "main" function that calls your HLS function.  If main returns 0 then the C simulation will be judged to pass.
I usually end up with a main.c under the testbench section and functionname.c in my source folder.  That will make HLS happy for your purposes.  Eventually, you should put some meaningful tests in main.c.
DSP in hardware and software
bdiouiska
Thank you a lot,
So what I did now is make an empty file in Top Function , and put my main function in Test bunch files ,
So it works and I didn't encounter the normal error , but this time i got error i think in the script . Do you have an idea about it ?and thanks a lot
aoifem
Hi @bdiouiska
Can you please provide the new error you are getting so the community can help you?
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
tedbooth
@bdiouiska ,
If you haven't done so already, you might want to take a look at UG871.  It is an HLS Tutorial that should take you through all of the steps to create, simulate and synthesize an IP.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug871-vivado-high-level-synthesis-tutorial.pdf
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
bdiouiska
Thank you all for responding , So what i did now is I put the same algroithm in Source file as well in the test bunch i've made some changes to make it more clear ,and what i got is this message : "Generating csim.exe" the Run C Simulation keeps and keeps rolling with no stop .thanks for your help .
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <math.h>
#include <string.h>
 int n1,n2,n3,i,j,k;
int h;
float Somme=0;
for (h=i;h<n1;h++)
return (Somme);
int h;
float Somme=0;
return(Somme);
int main()
    float nu,a,b;
    a=0.25;
    b=0.5;
    nu=0.6; //donnée
    scanf("%i",&n1);
        scanf("%i",&n2);
    scanf("%i",&n3);
for (i=0;i<n1;i++){
    scanf("%f",&X[i]);
for (i=0;i<n3;i++){
    scanf("%f",&Sd[i]);
for (i=0;i<n3;i++){
    scanf("%f",&es[i]);
for (i=0;i<n1;i++){
    for (j=0;j<n2;j++){
for (i=0;i<n2;i++){
    for (j=0;j<n3;j++){
 printf("%f",W[1,1]);
for (j=0;j<n2;j++)
for (i=0;i<n1;i++)
Y[j]=b+a*E[j];
// Fonction 2
for (k=0;k<n3;k++)
for (j=0;j<n2;j++)
Y1[k]=b+a*E1[k];
return 0;
russellesmith
You also get this error when you do not match the parenthesis {} in your test bench main() function.
