Participant jake8542
Question about changing custom ip using HLS in Vivado
Hi, I'm begineer of using Vivado HLS.
The project I'm looking into makes modules, like xxx.zip, using Vivado HLS and makes Vivado projects from them.
I've been trying to modify xxx.v file inside xxx.zip with adding output port that reflects internal state of the module.
Then, make Vivado take the zip file and make it as IP.
However, the output port isn't showing the output port that I've added.
Is this approach not viable?
Thank you for your help.
jwlee
Re: Question about changing custom ip using HLS in Vivado
Hi @jake8542 ,
Exporting the RTL as IP is generally recommended for the HLS designs and use that HLS generated IP in Vivado rather than directly creating the vivado project using the HDL generated with Vivado HLS.
I would propose the below approach that should fit your scenario.
1. Export the HLS design in the form of IP.
2. Create a new Vivado project and add that HLS created IP in the project.
3. Now edit the HLS IP by using the "Edit in IP Packager" option.
4. A new IP Packager project opens, modify the changes as required and then package the IP.
5. Later upgrade this HLS IP in the main vivado project as it would have got locked due to the modifications.
By this way, you should be able to do the changes in the HLS generated IP.
Hi @jake8542
There is a lot of documentation that I think could help you with this.
Could you take a look at some of the video series on HLS (Part 1 and Part 2 ).
There are also a lot of tutorials availabe in UG871
Aoife
Hi @jake8542 ,
Thanks for the tip!
Wow it's a nice tutorial. Thank you.
