Sequential access in BRAM
I have a problem when synthesizing the following code with HLS:
void fix(double PORT_A[SIZE]){
	#pragma HLS INTERFACE bram port=PORT_A
        double x1,x2;
        x1=PORT_A[0];
	x2=PORT_A[1];
	PORT_A[2]=x1+x2;
Basically, after the synthesis, besides the port I've defined as interface (PORT_A), HSL instantiates another BRAM port B.
By looking in the analysis perspective I've noticed that the following operations
x1=PORT_A[0];
x2=PORT_A[1];
are performed in parallel at the same cycle (and this force the synthesis to put a second BRAM).
Is there a way to tell HLS to serialize the two operations?
Advisor
Advisor
From UG902:
When using an ap_memory interface, specify the array targets using the RESOURCE
directive. If no target is specified for the arrays, Vivado HLS determines whether to use a
single or dual-port RAM interface.
In this case, it looks like HLS has decided that a dual-port interface makes sense. You need to tell it that it's only a single-port RAM using the RESOURCE pragma.
Advisor
Advisor
From UG902:
YES! This is the solution!
Putting this pragma saved me:
#pragma HLS RESOURCE variable=INOUT_PORT core=RAM_1P_BRAM
Many thanks for the support.
