Strange behavior of C/RTL cosimulation
I tried the following program with Vivado HLS 2018.2 in Windows 10 which copies a 16bit packed integer stream to an unpacked integer stream.
#include <ap_int.h>
#include <hls_stream.h>
#include <stdint.h>
void copy_ib2(int32_t w, int32_t h, hls::stream<ap_uint<16> > & in, hls::stream<uint8_t> & out)
#pragma HLS interface s_axilite port=h bundle=BUS_AXI4LS
#pragma HLS interface s_axilite port=w bundle=BUS_AXI4LS
#pragma HLS interface axis port=in
#pragma HLS interface axis port=out
ap_uint<16> bv;
for (int32_t i = 0; i < w * h; i++) {
int32_t x = i % w;
#pragma HLS pipeline II=1
if (i % 2 == 0) {
bv = in.read();
int32_t li = x % 2;
uint8_t v = bv.range((li + 1) * 8 - 1, li * 8);
out.write(v);
return;
#include <cstdio>
#include <ap_int.h>
#include <stdint.h>
void copy_ib2(int32_t w, int32_t h, hls::stream<ap_uint<16> > & in, hls::stream<uint8_t> & out);
int main(int argc, char *argv[])
hls::stream<ap_uint<16> > in;
hls::stream<uint8_t> out;
int32_t w = 6, h = 2;
for (int32_t i = 0; i < w * h; i+=2) {
ap_uint<16> b;
b.range(7, 0) = i;
b.range(15, 8) = i + 1;
in.write(b);
copy_ib2(w, h, in, out);
bool success = true;
uint8_t r = out.read();
if (r != i) {
printf("expects %d, actual %d\n", i, r);
success = false;
if (success) {
printf("Success!!\n");
return 0;
} else {
return 1;
It passes C-simulation, but does not pass C/RTL cosimulation.
The following is the result of C/RTL cosimulation.
INFO: [Common 17-206] Exiting xsim at Wed Nov 7 17:10:12 2018...
INFO: [COSIM 212-316] Starting C post checking ...
expects 1, actual 0
expects 3, actual 2
expects 5, actual 4
expects 7, actual 6
expects 8, actual 9
expects 9, actual 8
expects 10, actual 11
ERROR: [COSIM 212-361] C TB post check failed, nonzero return value '1'.
When I change ``w'' at declaration of ``x'' to a constant 6, it passes both C and C/RTL cosimulation.
Is this a bug of Vivado HLS?
Thank you in advance for your help.
Teacher xilinxacct
Re: Strange behavior of C/RTL cosimulation
@izumi.asakura
Remove the 'pipeline' pragma and it will work. (I think the interaction of the pipeline and the mod are not as you want)
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
Teacher xilinxacct
@izumi.asakura
Hope that helps
Visitor dong_group
Hello, recently I also meet with the same problem,my HLS project  also passed C-simulation, but did not pass C/RTL cosimulation. Did you resolved this problem? Could you please share the solution with me?
@xilinxacct
Thank you for your help and sorry for late reply.
As you mentioned, I also guess that the problem is due to the bad interaction of the pipeline pragma and mod op (I'd apprerciate it if you give any documentation about that.) Actually, I solved the problem by avoiding mod because I don't want to give up pipeline.
@dong_group
Sorry for the late reply.
I fixed the problem by avoiding mod in pipeline loops. As @xilinxacct mentioned, we should not use mod inside pipeline loops.
I hope this will help you.
Hi @izumi.asakura
Thank you for updating us with your solution.
Could you mark your answer as accepted so that other users can find it quickly in the future?
Aoife
