Visitor dommynik
Testbench error with gcc
everytime I start the C simulation with GCC or the Cosimulation I get the following errors:
INFO: [SIM 2] *************** CSIM start ***************
INFO: [SIM 4] CSIM will launch GCC as the compiler.
   Compiling ../../../../../testbench/axi_hmc_tb.cpp in debug mode
In file included from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/include-fixed/features.h:339:0,
                 from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/../../../../include/c++/4.6.3/x86_64-unknown-linux-gnu/bits/os_defines.h:40,
                 from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/../../../../include/c++/4.6.3/x86_64-unknown-linux-gnu/bits/c++config.h:393,
                 from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/../../../../include/c++/4.6.3/bits/stl_algobase.h:60,
                 from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/../../../../include/c++/4.6.3/deque:61,
                 from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/../../../../include/c++/4.6.3/queue:61,
                 from /opt/Xilinx/Vivado_HLS/2016.4/include/hls_stream.h:79,
                 from ../../../../../testbench/../inc/axi_hmc.h:3,
                 from ../../../../../testbench/axi_hmc_tb.cpp:1:
/usr/include/sys/cdefs.h:481:49: error: missing binary operator before token "("
In file included from /opt/Xilinx/Vivado_HLS/2016.4/include/hls_stream.h:92:0,
/usr/include/stdlib.h:183:17: error: missing binary operator before token "("
In file included from /opt/Xilinx/Vivado_HLS/2016.4/include/etc/ap_int_sim.h:75:0,
                 from /opt/Xilinx/Vivado_HLS/2016.4/include/ap_int.h:74,
                 from ../../../../../testbench/../inc/axi_hmc.h:4,
/usr/include/stdio.h:320:43: error: missing binary operator before token "("
/usr/include/stdio.h:399:17: error: missing binary operator before token "("
/usr/include/stdio.h:657:43: error: missing binary operator before token "("
In file included from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/include-fixed/limits.h:169:0,
                 from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/include-fixed/syslimits.h:7,
                 from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/include-fixed/limits.h:34,
                 from /opt/Xilinx/Vivado_HLS/2016.4/include/etc/ap_int_sim.h:97,
/usr/include/limits.h:145:17: error: missing binary operator before token "("
In file included from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/include/stdint.h:3:0,
                 from /opt/Xilinx/Vivado_HLS/2016.4/include/etc/ap_private.h:79,
                 from /opt/Xilinx/Vivado_HLS/2016.4/include/etc/ap_int_sim.h:98,
/usr/include/stdint.h:310:17: error: missing binary operator before token "("
In file included from /opt/Xilinx/Vivado_HLS/2016.4/include/etc/ap_private.h:122:0,
/usr/include/math.h:51:17: error: missing binary operator before token "("
/usr/include/math.h:126:17: error: missing binary operator before token "("
/usr/include/math.h:158:17: error: missing binary operator before token "("
In file included from /usr/include/math.h:213:0,
                 from /opt/Xilinx/Vivado_HLS/2016.4/include/etc/ap_private.h:122,
/usr/include/bits/mathcalls.h:118:17: error: missing binary operator before token "("
/usr/include/bits/mathcalls.h:299:17: error: missing binary operator before token "("
/usr/include/bits/mathcalls.h:318:17: error: missing binary operator before token "("
/usr/include/bits/mathcalls.h:387:17: error: missing binary operator before token "("
In file included from /usr/include/math.h:234:0,
In file included from /usr/include/math.h:281:0,
/usr/include/math.h:408:17: error: missing binary operator before token "("
/usr/include/math.h:628:17: error: missing binary operator before token "("
In file included from /opt/Xilinx/Vivado_HLS/2016.4/lnx64/tools/gcc/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.6.3/../../../../include/c++/4.6.3/cstring:44:0,
                 from /opt/Xilinx/Vivado_HLS/2016.4/include/etc/ap_private.h:124,
/usr/include/string.h:169:21: error: missing binary operator before token "("
/usr/include/string.h:178:43: error: missing binary operator before token "("
make: *** [csim.mk:73: obj/axi_hmc_tb.o] Error 1
CRITICAL WARNING: [SIM 100] CSim file generation failed: compilation error(s).
INFO: [SIM 3] *************** CSIM finish ***************
 Do you know that error and is there any workaround? I have a fresh installation of Antergos with GCC 6.3.1.
Teacher muzaffer
Re: Testbench error with gcc
@dommynik you probably have a typo in one of these files:
show the first 5 lines of axi_hmc.h and axi_hmc_tb.cpp
Visitor dommynik
@muzaffer
axi_hmc.h
#pragma once
#include <hls_stream.h>
#include <ap_int.h>
#define NUM_TAGS 512
#define NUM_TOKENS 16
axi_hmc_tb.cpp
#include "../inc/axi_hmc.h"
#include <iostream>
int main() {
	ReadAddress::Stream addressInStr;
	TagStream tagInStr;
	TokenStream tokenInStr;
The strange thing is that it works with the clang compiler but not with the gcc compiler. Therefore I assumed that there has to be some misconfiguration, either with gcc or Vivado.
Hi @dommynik,
I've had very similiar problem and was able to fix it.
In my case the problem was caused by GLIBC headers. My glibc version was too new for Vivado HLS (openSuse Tumbleweed with glibc 2.25). As you can see in the logs Vivado HLS is mixing some system-wide glibc headers (/usr/include/...) with it's own bundled files (e.g. features.h). This  causes a lot of headache because glibc headers define and use a lot of macros which can appear/disappear/move to another file.
In my case the problem was that Vivado HLS bundled it's own features.h file (which defines a lot of macros used by another glibc headers) but didn't bundle sys/cdefs.h. Because my system-wide /usr/include/sys/cdefs.h expects some macros which are missing in old, Vivado-bundled features.h the whole thing falls apart.
These steps fixed it for me:
  1. Download older glibc version (I used 2.17) and unpack it.
  2. Copy glibc-2.17/misc/sys/cdefs.h to Vivado_HLS/2017.1/lnx64/tools/gcc/lib/gcc/x86_64-unknown-linux-gnu/4.6.3/include-fixed/sys/ directory.
  3. Now I had problems with limits.h caused by another missing macro ( __GLIBC_USE() )
  4. Open Vivado_HLS/2017.1/lnx64/tools/gcc/lib/gcc/x86_64-unknown-linux-gnu/4.6.3/include-fixed/features.h and add this somewhere in the middle:
     /* Whether to use feature set F.  */
     #define __GLIBC_USE(F)  __GLIBC_USE_ ## F
Now I can go back to my real work.
Cheers,
Adrian
Observer corna
Maybe a bit late, however running
<Vivado install path>/Vivado/2017.3/lnx64/tools/gcc/libexec/gcc/x86_64-unknown-linux-gnu/4.6.3/install-tools/mkheaders <Vivado install path>/Vivado/2017.3/lnx64/tools/gcc
fixed the issue for me (Vivado 2017.3 on Ubuntu 17.10).
Observer kadionik
Hi corna.
I've discovered your tip since my last reading of this thread in march and it solved the problem of HLS simulation under Fedora 27 (glibc-headers too old in Vivado).
It works for me with Vivado HLS 2016.3 and 2018.1 (default installation under /opt/Xilinx).
For 2016.3:
$ sudo /opt/Xilinx/Vivado_HLS/2016.3/lnx64/tools/gcc/libexec/gcc/x86_64-unknown-linux-gnu/4.6.3/install-tools/mkheaders /opt/Xilinx/Vivado_HLS/2016.3/lnx64/tools/gcc/
For 2018.1:
$ sudo /opt/Xilinx/Vivado/2018.1/lnx64/tools/gcc/libexec/gcc/x86_64-unknown-linux-gnu/4.6.3/install-tools/mkheaders /opt/Xilinx/Vivado/2018.1/lnx64/tools/gcc
Many thanks!
Pat
Visitor bashid
it's also work for 2016.2
Thanks!
