monaz_yas
Unsupported enormous number of load/store instructions
Some errors related to big interface
The brief explanation of my code is as follows, would you please help me with the error in synthesize part?
void Encoder( dout_t o_array[N], din_t in_array[K]);
#pragma HLS latency min=1000
INTERFACE
in_array[64800]
short int
#pragma HLS INTERFACE bram port=in_array
INTERFACE
out_array[64800]
short int
#pragma HLS INTERFACE bram port= out_array
Resourece
H_v[32400][7];
unsigned short int
#pragma HLS RESOURCE variable=H_v core=ROM_2P
  • C simulation is run correctly.
  • The error for synthesize part is:
ERROR 1: [HLS 200-70] Failed building synthesis data model.
command 'ap_source' returned error code
    while executing
"source C:/LDPC_DVBS2_ENCODER/EN/EN/solution1/csynth.tcl"
    invoked from within
"hls::main C:/LDPC_DVBS2_ENCODER/EN/EN/solution1/csynth.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
   invoked from within
"hls_proc $argv"  EN:solution1  Apr 29, 2019, 6:47:59 AM
ERROR 2: [XFORM 203-1403] Unsupported enormous number of load/store instructions: 'Encoder'
u4223374
Advisor
Advisor
(1) This should be in the HLS forum.
(2) Since you haven't actually posted any code where a load or store occurs, debugging your "enormous number of load/store instructions" will be difficult. I would guess that it's got something to do with trying to read/write >64 elements per cycle (to process 64800 elements in 1000 cycles), when BRAM can only read or write a maximum of two elements per cycle.
monaz_yas
I really appreciate your responce. I think by Pragma you are able to understand I used BRAM for interface and ROM_2p for 2D_matrix. I can post my code here if it helps to debug it. By the wa is there any solution in this situation.
Sincerely.
scampbell
Adding file and comment from another post to your response @u4223374  ....
@monaz_yas wrote:
Re: Unsupported enormous number of load/store instructions
Sincerely.
scampbell
Hello @monaz_yas ,
As @u4223374 mentioned, you have a very large array size as inputs to your function. This is fine until you begin to parallelize the operations on those elements. Without seeing the code and directives it is hard to know for sure, but I agree that this is most likely the source of your error. If you wish, can you post the code and directives for further analysis?
Thank you,
Scott
