VivekJaganath
Urgent Help! is synthesis possible with usage of unordered maps, hash maps and vectors is C++ applications
Is it possible to use unordered maps, hash maps, and vectors is C++ applications and successfully accelerate it?
Is so how and any example for the same?
Any help will be much appreciated.
Tags (4)
xilinxacct
Professor
Professor
@VivekJaganath
If you are talking about synthesized hardware using HLS and the C++ syntax, then no. You cannot use any STL that would involve dynamic memory allocation.
Hope that helps.
If so, please mark as solution accepted. Kudos also welcomed
VivekJaganath
Thanks a ton. have you come across any C++ examples where tweaks have been made to convert these dynamic variables to fixed size?
