Variable latency warning
Hello everybody
To determine the latency of various code lines I would like to set the latency directive to some of my code lines using a label.
This would allow me to know where optimizations of my code are necessary (to consider switching from floating point to fixed-point representations) in order to achieve a given, tight latency constraint - possibly via comparison to the arithmetic blocks in my hand-crafted data dependency graph. Of course, some code lines may have a variable latency, but in this case I would just be happy to know the worst-case latency of that block.
An example (snippet from my code):
labelsincos:
sin1 = sin(mult1);
cos1 = cos(mult1);
During synthesis I get the following warning:
WARNING: [SCHED 204-71] Latency directive discarded for region labelsincossince region contains function calls with variable latency.
Side-note: mult1 is a float.
Of course, as these special code lines are implemented separately on a floating point unit, I can see the latency in the synthesis report. But usually I am not able to associate my code lines with their corresponding latency from the latency information in the report file.
So my question is:
How can I set a latency directive to a block with variable latency or associate code lines with their corresponding latency?
Any help will be much appreciated!
Cheers,
Michael
Re: Variable latency warning
I think the problem with this is that HLS tries to do it on functional boundaries. Within a function it'll reorder operations however it sees fit to accomplish your goals. The only way I could think of to see what you want to see is encapsulate the code in question in a function. Then you can force inline on or off. Forcing inline to be off will keep the function boundary and you can see how long the function takes (note this adds a cycle of latency and slows everything down). Once you're done analyzing you can turn inline back on.
Thank you very much, your solution works very well for me.
Cheers,
Michael
