07-17-2019 04:09 AM
I have to add a directive when I make example 4c in the Zynq book application book, but the directive editor doesn't open when I want to. Despite all my attempts, I could not solve the problem. The related picture is given below.
Vivado HLS 2018.3
Windows 10
Zedboard
07-17-2019 08:55 PM
Hi @balci29 ,
Are you using multiple monitors ? If so can you please check if the insert directive pop up has been opened in the other monitor ?
Also, what if you try to open the example HLS design and try to change the directive there ? Do you see the directive dialog box ?
07-19-2019 08:28 AM
Thnks for reply.
I'm using single monitor. I tried to change the project by opening it and I did not get results. I can't just add directives to functions, I can add to variables. You can also watch it in the video below.
05-28-2020 02:09 AM
I have the same problem with ,
Vivado HLS 2019.1
Zynq_Book tutorial 3A 3B
Windows 10
Zedboard
11-30-2020 04:53 AM
Hello, I have the same problem too,
anybody have a solution of this problem?
thank you in advance
