Vivado HLS 2015.2 opening problem
Hi Folks,
I am using Vivado 2015.2 package.
when click on vivado hls, tool is not opening. That is showing one message in dos mode and goes off.
That message is: 'wscript.EXE' is not recognized as an internal or external command, operable program or batch file.
How  to fix this?
Please suggest me.
I attaching message screenshot.
Thanks and Best Regards
Vinod Sajjan
@vinodsajjan,
Can you run the settings64-Vivado_High_Level_Synthesis.bat file present here: C:\Xilinx\Vivado_HLS\2015.2
Also, you can try adding this to PATH environment variable: C:\Xilinx\Vivado_HLS\2015.2\bin
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
Hi @vinodsajjan,
What is the OS you are targeting?
Please go through page-9 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf for list of supported OS for 2015.2.
Also try once from the command line and see if you are able to invoke the tool.
Arpan
Hi @arpansur,
Thanks for response.
I am using windows 8.1 pro and vivado design suit and SDK is working fine.
Previously i am using vivado HLS and working fine and suddenly occurring this issue.
I reinstall complete vivado software and still same error and issue.
Vinod Sajjan
Hi @nupurs,
Thank you for response.
I tried with as you suggested step.
I ran .bat file and pasting PATH into environmental variable. And I reinstalled complete vivado software and still same issue.
what can i do next? please suggest me.
Vinod Sajjan
I have exactly the same problem after installing 2017.4.
Even 2017.1 which used to work fine, doesn't anymore...
Any solution finally found?
Jerome
Hi @be_rf_cs,
you Do one thing right click on Vivado HLS icon and select run as Administrator.
Right now i doing like this and  vivado HLS is opening, may be for u to works just try once.
Thanks and Best regards
Vinod Sajjan
Hi Vinod,
It works! Thank you very much.
Jerome
I've finally solved the problem by adding C:\Windows\System32 in my path.
