pswetalina
Vivado HLS BRAM and ap_memory usage.
Hi.
I have an IP created in Vivado HLS for a simple module which takes in arrays as input arguments. Now I use the "ap_memory" interface and "1-Port BRAM" resource directive for the arrays. I used this IP to integrate with the Zynq processing System in Vivado and make all the connections. The thing is I do not have a BRAM in my block design. But still all my values are getting written and processed.
Where is it stored then if I do not have a memory generator block in my design?
Tags (3)
debrajr
Have you checked the generated RTL(VHDL/Verilog) files in HLS after Csynth. That would give you a clue!
Debraj
debrajr
Debraj
pswetalina
Thanks for the reply.
I want to connect my IP to an external BRAM. I have 5 arrays as input arguments. Is it possible to bundle all the input ports to a single input port and connect it to an external BRAM in Vivado.
There are tutorials lacking on BRAM usage for both Vivado 2014.2 and Vivado HLS.
Thanks again!
debrajr
Even if you bundle, how are you planning to drive them in your design?
Debraj
