Vivado HLS (Eclipse) buttons toolbar not showing
Does anyone know why I cannot see the buttons toolbar on Eclipse when opening a second window?
It worked last week, I even had 3 windows opened. Now the buttons are partially hidden as you can see in the attached image. Very strange.
Cerilet
Hello, I don't know why you can't see it. However you can see it if you click rigth on it and select Restore Hidden Toolbar Entries
Hey @rosa_bpc,
thanks for your reply, but I have already tried that and it does nothing. Actually, when right-clicking on the part of the toolbar which is hidden, it does not show any option.
Cerilet
Hi @cerilet, like @rosa_bpc, don't know why the toolbar is not showing. Haven't heard nor seen of this before. How did you launch the second window? I assume you launched the first window in the same way. What OS are you using?
Hi @peadard,
I launch Vivado HLS using the start menu. I use Windows 7 64-bit.
I launched several instances of Vivado HLS 2017.1 and it does not have this problem. Apparently it only happens with the 2017.2 version.
Very weird.
Thanks @cerilet, yes, very weird indeed! Does it now happen every time you start a launch a second HLS window? Or just occasionally?
If every time, try launching Vivado HLS from the Vivado HLS 2017.2 Command Prompt i.e. launch the command prompt from the start menu, navigate to the project directory and launch the GUI, vivado_hls.
Everytime I do it. But last week it didn't.
When launching it from the command prompt it behaves the same way.
Ok, I have found a workaround.
Remove the .metadata folder in C:\Users\[your_user]\.vivado_hls\2017.2 and you will be able to open several instances of Vivado HLS without any problem.
You might have to do it again every time you close HLS.
Cerilet
