Vivado HLS generates syntax error-Verilog code
When I use array in SystemC, a problem was happened.
If I use array in SC_MODULE, Vivado HLS 2019.2 generates syntax error-Verilog codes.
such as
In SystemC, as follows,
sc_uint<4> X[4];
and in generated Verilog, as follows, waste "end" is the error
always @(*)begin
end
end
Arrays are not surported in SystemC?
Please tell me how to use array with no syntax error-Verilog code.
