shjang
What's difference between hls::vector and array?
Hi.
I'm trying to develop my own accelerated kernel on Vitis tool.
And I found that user can use hls::vector and array variable both.
But I cannot understand which is the difference there in both type.
Is there any difference in implemented hardware?
xilinxacct
Professor
Professor
@shjang
An array is a base pointer to some memory... A vector (from STL) can dynamically grow, and has knowledge of its size. In HLS, there cannot be dynamic growth, as there is no dynamic memory. In synthesizable code, STL vectors cannot be used... See this for more info on hls::vector
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/vitis_hls_coding_styles.html
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed.
xilinxacct
Professor
Professor
@shjang
Hope that Helps
