fole_name
Why this tripcount doesn't work?
I have put a tripcount in the innest for cycle layer,but there are still some "?" in systhesis result. Can anybody help me? The following is the code: for(int l = 2; l <= 512; l=l<<1){ int m = l / 2; for(int i = 0;i<512;i+=l) { for(int j = 0; j < m; j++){ #pragma HLS LOOP_TRIPCOUNT min=1 max=256 real_tempt = omg.real[512 / l * j] * a->real[i+j+m] - omg.imag[512 / l * j] * a->imag[i+j+m]; imag_tempt = omg.imag[512 / l * j] * a->real[i+j+m] + omg.real[512 / l * j] * a->imag[i+j+m]; a->real[i+j+m] = a->real[i+j] - real_tempt; a->imag[i+j+m] = a->imag[i+j] - imag_tempt; a->real[i+j] = a->real[i+j] + real_tempt; a->imag[i+j] = a->imag[i+j] + imag_tempt; } } }
u4223374
Advisor
Advisor
As far as I can tell, you've got a triple-nested loop, and you've only specified a tripcount on the inner loop. You need to specify it on the other two as well. In addition to that, I suspect that you're using floating-point operations here. These may not have fixed latency.
viswanad
can you please share complete code to easily reproduce? Which version of Vivado HLs you are trying?
Viswanadh
u4223374
Advisor
Advisor
fole_name
Yeah, you are quite right. I specified it on the middle loop ,then it works. Thanks
