coding style: MAC
hi,
i'm struggling with describing an multiply accumulate. The line is similar to
accu[i] += a*b[i];
the code is work, even in VHDL, but the resources are used suboptimal. I'm using a V6 but the DSP48E1 are only used for the multiplication not for the accumulation too. The accumulation is done by seperate logic.
The next: it would be nice, if i can cascade the DSP48E1 to use the ACOUT/ACIN (or BCOUT/BCIN) as shift-register. Actually, this will be also implement as seperate logic.
Does anyone know, how to code it correctly?
thanks
Re: coding style: MAC
The solution seems to be found.
Althought declared as static, the accu wasn't registered and therefore not pulled into the DSP48E1.
The following code worked as expected:
template<class T>
T Reg(T in)
#pragma HLS PIPELINE
#pragma HLS INLINE off
#pragma HLS INTERFACE port=return register
return in;
int mac(short a_in, short b_in)
static int c = 0;
c = Reg(c + a_in * b_in);
return c;
thanks @all
Are you writing this code in C?
Debraj
at the moment i'm using the c++ compiler without classes
you can use dsp48 macro core for your application
Here is AR which tell you How to connect up the PCIN when it is not connected to the PCOUT of an adjacent DSP48 slice?
http://www.xilinx.com/support/answers/44205.html
Thanks and Regards
Balkrishan
#include "array_arith.h"
void array_arith (dio_t d[5]) {
  static int acc = 0;
  int i;
    for (i=0;i<4;i++) {
    acc += d[i+1];
    d[i] = acc;
Thanks and Regards
Balkrishan
It's possible to be put into DSP and post-adder if width(accu[i])<=48, width(a,b[i])<=(18,25) and width(a+b[i])<=width(accu[i]).
brucey
this conditions are met
a, b = 8 bit ns
accu = 30 bit ns
Maybe due to the fact, that multiplications are done in a separate component, the XST does not interfere a MAC. Even if hierarchy is turned off.
template<class T>
T Reg(T in)
return in;
static int c = 0;
return c;
thanks @all
