cosimulation failed when the 'for-loop' is set to 'rewind'
In my C design, I set 'dataflow' for the function, and if the 'for-loop' is only pipelining, the cosimulation is correct. But if, the for-loop is set to pipeline and rewind, the cosimulation will fail.
Could anyone give me some suggestions?
Re: cosimulation failed when the 'for-loop' is set to 'rewind'
Hi @araongao2015
Please check the following ARs.
https://www.xilinx.com/support/answers/60550.html
For debugging te co-sim failures, https://www.xilinx.com/support/answers/61063.html
Thanks,Vijay
