different utilization report between systhesis and export RTL
Hi all,
I have a question about ultilization report between systhesis and export RTL.
In the export RTL, It uses additional SRL & SLICE and orther values is different synthesis report.
Could you please explain it for me?
Thank you,
Quan Nguyen
The report is as bellow:
################Synthesis#############
* Summary:
| Name | BRAM_18K| DSP48E| FF | LUT |
|DSP | -| -| -| -|
|Expression | -| -| -| -|
|FIFO | 3| -| 152| 423|
|Instance | 5| 33| 7567| 11694|
|Memory | -| -| -| -|
|Multiplexer | -| -| -| 11|
|Register | -| -| 7| -|
|Total | 8| 33| 7726| 12128|
|Available | 120| 80| 35200| 17600|
|Utilization (%) | 6| 41| 21| 68|
#####Export RTL#####
#=== Resource usage ===
SLICE: 2279
LUT: 6534
FF: 7199
DSP: 33
BRAM: 8
SRL: 508
Re: different utilization report between systhesis and export RTL
The synthesis report is just a roughly estimation, you have to export the design and at least synthesize it to get a reliable utilization, which also depends on other factors releted to the full design like FPGA occupation and congestion.
The synthesis report also depends by the tooling release, see posts 1 2
HI @hongquan18196,
As correctly indicated by @baltamthe utilization after exporting the RTL as IP with synthesis, place and route options will give the exact utilization values whereas synthesis option in HLS converts the c/c++ language into HDL giving just utilization estimates but not the exact utilization.
