Observer taoluwork
drivers not generated in impl folder
Hi experts,
I had an issue that the "drivers" folder not generated in my impl folder. So that I cannot find my "xModule.h" file in my SDK design. My project is targeted at board zc706 with zynq-7 on it. What is the possible reason for this? I've been run synthesis and export many times but not solve this. I guess it could be the settings but cannot locate this in the tutorial.
Please help!
Thanks!
Taurus
Re: drivers not generated in impl folder
@taoluwork
Is your IP streaming or AXI slave? If you have implemented your HLS IP as streaming then it will not require driver so driver folder is not generated.
Regards, abhidan@logictronix.com
Please mark the Answer as "Accept as solution" if information provided solves your query. Give Kudos if you think it was helpful and reply oriented.
Observer taoluwork
Quick correction: the drivers folder should be under solution1/impl/ip/drivers.
I can see that in some example project but my design did not generate it.
Observer taoluwork
Update: I can successfully generate the drivers folder on a very simple design using default settings. Thus the tool chain / setting has no issue. However, I cannot generate that even I recreate a project, still.
Question: I've followed the tutorial to use module in SDK by including the xModule.h file in the drivers folder. If that folder is not necessarily generated, how could I use my module in SDK or in vivado system design?
@taoluwork
Observer taoluwork
Hi, thank you for your reply. I think you are right. That driver is not generated necessarily. I did not set my IP interface, but I can read result from memory directly. Thanks!
