error: expected ')'
void pavilion_hw(T LabelS1[DIM1][DIM2], T out predict_label1[DIMa][DIMb], T precision1[DIMc][DIMd],T prob_estimates_t1[DIMe][DIMf])
error :
where labels1: input and predict_label1 T precision1,T prob_estimates_t1:output
src1/main.cpp:214:47: error: expected ')'
Advisor
Advisor
This is not a valid declaration. C does not have the port direction defined; HLS just infers that from the code. Delete the "out" and it should work.
Can you please provide detail . You can refer some example design here
https://github.com/Xilinx/HLx_Examples
you can also check this quick look video
https://www.xilinx.com/video/hardware/getting-started-vivado-high-level-synthesis.html
Thanks and Regards
Balkrishan
