error when running C/RTL co-simulation
Hello guys,
I'm studying HLS, I designed a simple module which is a floating point accumulator. I encountered this error when I was running C/RTL co-simulation:
ERROR: [XSIM 43-3238] Failed to link the design.
ERROR: Please check the snapshot name which is created during 'xelab',the current snapshot name "xsim.dir/accum/xsimk.exe" does not exist
It didn't happen when I run co-simulation for the tutorial designs. My design passed the simulation and synthesis program didn't report any errors.  So I think there is something wrong with my code:
DUT:
#include <iostream>
#include "accum.h"
using namespace std;
double accum(double input[100]){
	double output = 0;
	accum_label0:for (int i=0;i<100;i++){
		output = output + input[i];
	return output;
Testbench:
#include "accum.h"
#include <iostream>
int main(){
	double input[100];
    double output_sw=0;
    double output_hw;
    for(int i=0;i<100;i++){
    	input[i] = i;
    	output_sw=output_sw+input[i];
    output_hw = accum(input);
    cout<<"the software result:"<<output_sw<<"\n";
    cout<<"the hardware result:"<<output_hw<<"\n";
    if(output_sw==output_hw){
    	cout<<"compare success!"<<"\n";
    	return 0;
    else if(output_sw!=output_hw){
    	cout<<"compare failed!"<<"\n";
    	return 1;
I'm really confused about it.
Thanks in advance,
Derick
Teacher muzaffer
Re: error when running C/RTL co-simulation
@derickshi I ran your system with the following script and I had no problems with cosim. What OS and Vivado version are you using?
open_project -reset accum
set_top accum
add_files dut.cpp -cflags "-DFIXED"
add_files -tb tb.cpp -cflags "-I/opt/Xilinx/Vivado_HLS/2015.4/include -std=c++0x"
open_solution -reset "solution1"
#set_part {xc7z045iffv900-2l}
#set_part kintexu
#set_part xc7z020iclg400-1l
set_part xc7z020clg400-2
#set_part xc7z030sbv485-2
#set_part {xcku040-fbva900-2-e}
#set_part {xcku040-sfva784-1-c}
create_clock -period 5 -name default
#source "directives.tcl"
#csim_design
csynth_design
cosim_design
#export_design -evaluate verilog -format ip_catalog
export_design -format ip_catalog
exit
@muzaffer thanks for the reply. My OS is windows 7 and I'm using Vivado HLS 2016.2.
@muzaffer
After I removed the loop unroll directive for the loop, the errors are just gone. Is it because the loop in my code has data dependency so it can't be unrolled?
