Observer mustafa60
hls::mat () error
hi all,
 I have a problem and I am stuck. I wanna try a code to make a HLS IP for my video processing purposes. The compiler gives an error while synthisizing the cpp code.
Compiling ../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/test.cpp in debug mode
Compiling ../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/opencv_top.cpp in debug mode
Compiling ../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/top.cpp in debug mode
In file included from C:/Xilinx/Vivado_HLS/2015.4/include/floating_point_v7_0_bitacc_cmodel.h:143:0,
from C:/Xilinx/Vivado_HLS/2015.4/include/hls_half.h:40,
from C:/Xilinx/Vivado_HLS/2015.4/include/hls/utils/x_hls_utils.h:37,
from C:/Xilinx/Vivado_HLS/2015.4/include/hls/hls_axi_io.h:40,
from C:/Xilinx/Vivado_HLS/2015.4/include/hls_video.h:48,
from C:/Xilinx/Vivado_HLS/2015.4/include/hls_opencv.h:50,
from ../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/test.cpp:50:
C:/Xilinx/Vivado_HLS/2015.4/include/gmp.h:62:0: warning: "__GMP_LIBGMP_DLL" redefined [enabled by default]
C:/Xilinx/Vivado_HLS/2015.4/include/floating_point_v7_0_bitacc_cmodel.h:135:0: note: this is the location of the previous definition
from ../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/opencv_top.cpp:44:
from ../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/top.h:47,
from ../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/top.cpp:43:
../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/top.cpp: In function 'void image_filter(AXI_STREAM&, AXI_STREAM&, long long unsigned int*, int, int)':
../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/top.cpp:72:39: error: no matching function for call to 'Sum(GRAY_IMAGE&)'
../../../../../FPGA-Motion-Detector-master/Vivado_HLS_MotionDetect/src_files/top.cpp:72:39: note: candidate is:
C:/Xilinx/Vivado_HLS/2015.4/include/hls/hls_video_arithm.h:1027:34: note: template<class DST_T, int ROWS, int COLS, int SRC_T> hls::Scalar<(((SRC_T & ((512 - 1) << 4)) >> 4) + 1), DST_T> hls::Sum(hls::Mat<ROWS, COLS, T>&)
make: *** [obj/top.o] Error 1
@E [SIM-1] 'csim_design' failed: compilation error(s).
and the code is
Modified by Russell Barnes for ECE 253 Final Project, Fall 2016
* © Copyright 2013 Xilinx, Inc. All rights reserved.
* This file contains confidential and proprietary information of Xilinx,
* Inc. and is protected under U.S. and international copyright and other
* intellectual property laws.
* DISCLAIMER
* This disclaimer is not a license and does not grant any rights to the
* materials distributed herewith. Except as otherwise provided in a valid
* license issued to you by Xilinx, and to the maximum extent permitted by
* applicable law: (1) THESE MATERIALS ARE MADE AVAILABLE "AS IS" AND WITH
* ALL FAULTS, AND XILINX HEREBY DISCLAIMS ALL WARRANTIES AND CONDITIONS,
* EXPRESS, IMPLIED, OR STATUTORY, INCLUDING BUT NOT LIMITED TO WARRANTIES
* OF MERCHANTABILITY, NON-INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR
* PURPOSE; and (2) Xilinx shall not be liable (whether in contract or
* tort, including negligence, or under any other theory of liability)
* for any loss or damage of any kind or nature related to, arising under
* or in connection with these materials, including for any direct, or any
* indirect, special, incidental, or consequential loss or damage (including
* loss of data, profits, goodwill, or any type of loss or damage suffered
* as a result of any action brought by a third party) even if such damage
* or loss was reasonably foreseeable or Xilinx had been advised of the
* possibility of the same.
* CRITICAL APPLICATIONS
* Xilinx products are not designed or intended to be fail-safe, or for use
* in any application requiring fail-safe performance, such as life-support
* or safety devices or systems, Class III medical devices, nuclear facilities,
* applications related to the deployment of airbags, or any other applications
* that could lead to death, personal injury, or severe property or environmental
* damage (individually and collectively, "Critical Applications"). Customer
* assumes the sole risk and liability of any use of Xilinx products in Critical
* Applications, subject only to applicable laws and regulations governing
* limitations on product liability.
* THIS COPYRIGHT NOTICE AND DISCLAIMER MUST BE RETAINED AS PART OF THIS FILE AT
* ALL TIMES.
#include "top.h"
void image_filter(AXI_STREAM& video_in1, AXI_STREAM& video_in2, unsigned long long *result, int rows, int cols) {
//Create AXI streaming interfaces for the core
#pragma HLS INTERFACE axis port=video_in1
#pragma HLS INTERFACE axis port=video_in2
#pragma HLS INTERFACE s_axilite port=result bundle=OUTPUT
#pragma HLS INTERFACE s_axilite port=rows bundle=CONTROL_BUS offset=0x14
#pragma HLS INTERFACE s_axilite port=cols bundle=CONTROL_BUS offset=0x1C
#pragma HLS INTERFACE ap_stable port=rows
#pragma HLS INTERFACE ap_stable port=cols
#pragma HLS INTERFACE ap_stable port=return
GRAY_IMAGE img_0(rows, cols);
GRAY_IMAGE img_1(rows, cols);
GRAY_IMAGE img_diff(rows, cols);
hls::Scalar<1, unsigned long long> result_pixel(0);
#pragma HLS dataflow
hls::AXIvideo2Mat(video_in1, img_0);
hls::AXIvideo2Mat(video_in2, img_1);
// Take difference between frames
hls::AbsDiff(img_0, img_1, img_diff);
// Accumulate
result_pixel = hls::Sum( img_diff );    // ERROR İS GİVEN HERE
*result = result_pixel.val[0];
I couldnt understand whether a header file or something is missing or not.
Re: hls::mat () error
top.h is not included in the attachment that you sent. Can you add it?
Nithin
Observer mustafa60
top.h is in the attachment file. btw, I dont know whether it helps or not but I am using vivado HLS 2018.3 and the code is written in an old version around 2016.2.
Can you archive the HLS project and send it, i am facing some other errors trying to reproduce the issue
Nithin
Observer mustafa60
Yes of course ,  I am facing this errors too,   I follow the header files and  discover that the input argument of hls:Sum can be wrong and arranged it in such a way described below.
result_pixel = hls::Sum<unsigned long long, MAX_HEIGHT,MAX_WIDTH,HLS_8UC1>(img_diff);
 But gives another error which says the input images cannot be found.
Observer mustafa60
Since ı cannot add more than 6 files the other are in the attachment.
