Visitor xiaopengyou
hls sobel C synthesis error
ERROR: [HLS 200-70] Compilation errors found: Pragma processor failed: In file included from sobel/src/Top.cpp:1:
sobel/src/top.h:15:40: error: use of undeclared identifier 'AXI_STREAM'
typedef hls::stream<ap_axiu<16,1,1,1>> AXI_STREAM;
sobel/src/top.h:15:50: error: type name requires a specifier or qualifier
sobel/src/top.h:19:6: error: variable has incomplete type 'void'
void hls_sobel(AXI_STREAM& src_axi,AXI_STREAM& dst_axi,int rows, int cols);
sobel/src/top.h:19:16: error: use of undeclared identifier 'AXI_STREAM'
sobel/src/top.h:19:28: error: use of undeclared identifier 'src_axi'
sobel/src/Top.cpp:3:6: error: variable has incomplete type 'void'
void hls_sobel(AXI_STREAM& video_in,AXI_STREAM& video_out,int rows, int cols)
sobel/src/Top.cpp:3:16: error: use of undeclared identifier 'AXI_STREAM'
sobel/src/Top.cpp:3:28: error: use of undeclared identifier 'video_in'
sobel/src/Top.cpp:3:78: error: expected ';' after top level declarator
9 errors generated.
Failed checking during preprocessing.
    while executing
"source H:/PYNQ-Z2/hls_example_data/sobel/sobel/solution1/csynth.tcl"
    invoked from within
"hls::main H:/PYNQ-Z2/hls_example_data/sobel/sobel/solution1/csynth.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
Finished C synthesis.
Visitor xiaopengyou
Re: hls sobel C synthesis error
The answer is
typedef hls::stream<ap_axiu<16,1,1,1>(There's a space here) >            AXI_STREAM;
Visitor xiaopengyou
The answer is
