Teacher xilinxacct
how to avoid HLS ARRAY_PARTITION stall potential?
If you have an array and you want to process the first half and last half in parallel, you can use the pragma HLS ARRAY_PARTITION variable=buf block factor=2
But, this by nature, give the potential for a stall at the buf[1] position
other factors up to the ‘complete’ introduce more potential (e.g factor 4 would have potential at s[2] & s[3])… complete avoids this by implementing FIFO, but this is a large expansion in utilization, and overkill for the need.
Is there a different pragma to use to avoid the stall potential OR parameter on this pragma to do likewise OR some method to remove the potential?
Note: cyclic is not an option for this particular case, as the order of the items in the buffer are significant.
Tags (2)
Scholar u4223374
Re: how to avoid HLS ARRAY_PARTITION stall potential?
I'm not sure how this can cause a stall. I've regularly used arrays that are effectively block partitioned and have never had HLS actually stall while accessing them. You can obviously hit dependency constraints, but that's a hardware limitation rather than a software one.
Scholar u4223374
Teacher xilinxacct
@u4223374
That's what I thought too... Glad you confirmed it is the best it can be, and I can ignore the warning and know there is no room for a more optimal pattern.
Thanks again
