Visitor kingshuk1000
improve loop initiation interval
I am trying to achieve an initiation interval of one in the following loop. But I am not able to reduce the Initiation Interval below 11. How should I fix this?
#define numFU 100
#define osize 10
#define wsize 32
void datapath(float* data, float* wpacket, int* wsel, int* psel,int* outID,int* out){
int reg_psel[numFU];
#pragma HLS ARRAY_PARTITION variable=reg_psel dim=1
int reg_wsel[numFU];
#pragma HLS ARRAY_PARTITION variable=reg_wsel dim=1
float reg_data[numFU];
#pragma HLS ARRAY_PARTITION variable=reg_data dim=1
float reg_wpacket[numFU];
#pragma HLS ARRAY_PARTITION variable=reg_wpacket dim=1
float ram_po[numFU][osize];
#pragma HLS dependence variable=ram_po intra false
#pragma HLS ARRAY_PARTITION variable=ram_po dim=1
#pragma HLS RESOURCE variable=ram_po core=RAM_T2P_BRAM
float reg_outID[numFU];
#pragma HLS ARRAY_PARTITION variable=reg_outID dim=1
float reg_out[numFU+1];
#pragma HLS ARRAY_PARTITION variable=reg_out dim=1
reg_out[0]=0;
float ram_weights[numFU][wsize];
#pragma HLS ARRAY_PARTITION variable=ram_weights dim=1
float temp[numFU];
#pragma HLS ARRAY_PARTITION variable=temp dim=1
int prev_addr[numFU];
#pragma HLS ARRAY_PARTITION variable=prev_addr dim=1
inf_loop:while(1){
#pragma HLS PIPELINE II=1
reg_data[0] = *data;
reg_wpacket[0] = *wpacket;
reg_psel[0] = *psel;
reg_wsel[0] = *wsel;
int i=0;
//update partial outputs
lbl_update:for (int i=numFU-1;i>=0;i--){
#pragma HLS UNROLL
int po_addr=reg_psel[i];
int w_addr =reg_wsel[i];
reg_out[i+1] = reg_outID[i]==i?ram_po[i][po_addr]:reg_out[i];
float v = ram_weights[i][w_addr]*reg_data[i];
if (prev_addr[i]!=po_addr){
ram_po[i][prev_addr[i]] = reg_outID[i]==i? 0:temp[i];
temp[i]=(prev_addr[i]==po_addr?temp[i]:ram_po[i][po_addr])+v;
prev_addr[i] = po_addr;
*out=reg_out[numFU];
Re: improve loop initiation interval
I updated the code a little to pinpoint the issue.
#define numFU 100
#define osize 10
#define wsize 32
reg_out[0]=0;
float temp[numFU];
inf_loop:while(1){
int i=0;
#pragma HLS UNROLL
//#pragma HLS dependence variable=temp intra false
temp[i]=ram_po[i][po_addr];
else{
temp[i]=temp[i]+v;
The synthesis tool is complaining that it is "unable to enforce a carried dependency constraint between store operation on temp[0] at
and load operation on temp[0] at
temp[i]=temp[i]+v;
The above lines are in if and else block respectively so two writes do not occur at the same time.
My question is that since I have partitioned temp, temp[0] should be just a register. In that case, shouldn't it be possible to do read and write on temp[0] in same clock cycle?
