dadduni
input array does not reshape
I've the following code. I want to have 16 input parallel BRAM each one 512 long. Why the reshaping is not working?
void cov(int mat_in[512][16], int mat_out[16][16]){
	int mat_temp_in[512][16];
	int mat_temp_out[16][16];
#pragma HLS array_reshape variable=mat_temp_in complete dim=2
#pragma HLS array_reshape variable=mat_temp_out complete dim=2
If in "variable" I put mat_in it's the same: in the synthesis I obtain always just one input port and not 16 as I want.
Any suggestion?
Thank You
joancab
If by "input ports" you mean the ports in the IP block you generate, I think ARRAY_RESHAPE is not for that. With ARRAY_RESHAPE, arrays are internally reshaped to speed up internal processing (for example a loop to do N/2, N/4, etc. iterations instead of N), but it won't create a number of ports.
u4223374
Advisor
Advisor
If you want 16 separate ports, use the array_partition pragma rather than array_reshape. Reshaping the array first partitions it, but then recombines the partitioned array into wider words so you still end up with a single port.
