rlatlwnd00
timing analysis AXI4 -stream using HLS sobelfilter
Hello, I'm S.J Kim
I analyze AXI4-STREAM for mapping the input data
but, OUT_STREAM_TVALID is not operation.
I set to random clock (INPUT tvalid,tready,tuser,reset,clk, etc. )
but, OUTPUT_STREAM_TVALID is not operation.
can you tell me what is the problem?
i attached the source file.
thanks you.
hpoetzl
Voyager
Voyager
Hey @rlatlwnd00
The project you attached is missing the sobel_filter sources so it's hard to tell why this fails.
Also note that you are on a quite old version of Vivado (2014.4), so it might be a good idea to upgrade.
All the best,
Herbert
-------------- Yes, I do this for fun!
florentw
The issue is probably that the core needs to be reseted first
Florent
