ahmedkhazal
vivado HLS with floating points
Dear friend
my question is :
I want to implement the neural network algorithms in FPGA .
is that possible to implement floating points numbers using VivadoHLS and SDK  in FPGA zynq7020? or I have to convert the floating points to integer numbers?
thanks
hpoetzl
Hey @ahmedkhazal,
It is possible to use floating point in FPGA and SDK, but it will be rather inefficient for your purpose.
Using fixed point or integer numbers instead will reduce the footprint per node and increase the performance.
Best,
Herbert
hpoetzl
Hey @ahmedkhazal,
Best,
Herbert
u4223374
Advisor
Advisor
As @hpoetzl has said, integer or fixed-point will save a huge amount of space. I've even seen some interesting papers about binary neural networks (where the values are just 0 or 1), which is potentially extremely FPGA-friendly (because you can do a binary operation in a single LUT, whereas even integer or fixed-point will require DSP slices).
ahmedkhazal
thanks, friend , but the algorithm that I want to use is MLP that use a floating point, so is it supported by Vivado HLS?
santhiya1702
I am in the process of implementing 3 layer perceptron in vhdl. I used float32 for inputs. When adding 2 float32 numbers , the result is a float32 and the answer is correct. But when I multiply 2 float32 numbers, I am getting the resultant as float32 but with all zeros.
Could not find which datatype I have to use for implementing decimal in vhdl.
I went ahead and i implemented a feed forward network with real numbers and successfully did the simulation in Vivado 2017.4. But could not synthesize in Nexys-4 DDR board.
Santhiya, Miami University, Ohio.
u4223374
Advisor
Advisor
@santhiya1702In VHDL, there aren't any suitable data types. HDLs (like VHDL and Verilog) don't do floating-point natively, because handling them is very challenging. In particular, almost all floating-point operations are multi-cycle processes, which makes them largely incompatible with the assumptions of HDLs (that basic operations can be done in one cycle and so the user can specify what happens on every cycle).
From here you have two options:
- The Xilinx floating-point IP core, which can do floating-point math for you (but it'll take several cycles at the bare minimum, and a lot of resources).
- Convert to HLS. HLS doesn't let the user decide what happens on each cycle, which allows it to do complex multi-cycle operations. In this case, it'll use the Xilinx floating-point IP core for the maths.
- Convert to fixed-point. This will be challenging, but it'll give you a much more efficient (in both speed and resources) design than floating-point.
