2018.3 multithreading contradiction
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug904-vivado-implementation.pdf page 7 says: "The default number of maximum simultaneous threads is based on the OS. For Windows systems, the limit is 2; for Linux systems the default is 8." yet the vivado 2018.3 lets me select up to 8 "jobs" (which are supposed to equal CPU cores).
1. Is the information I quoted still true for 2018.3?
2. If I have an 8 core processor, am I getting a 4x performance boost by running vivado on linux instead of windows 10?
Re: 2018.3 multithreading contradiction
The real issue is that general.maxThreads is set to 2 for some absolutely insane reason on windows. No good reason at all to do that. It should always be set to however many cores are available on the machine. There is a massive speed difference setting it to 8 vs the default of 2. wtf xilinx!?
set_param general.maxThreads 8
Scholar watari
Hi @david12341234
Almost all no.
For example, even if you use too much cores to compile the design, compile time of simple design is almost same as single core processor's.
It depends on your design.
However, if your design is large size and you can prepare huge memory size, I suggest using Linux OS with multi cores.
You can reduce compile time.
Best regards,
