Observer kangqiaoyibie
A fixed 600ps delay IDELAY ?
I use IDELAYE2 and IDELAYCTRL to add delay time for a signal.
I found that the delay time = fixed delay + tap* IDELAY_VALUE.
Where can I find the introduction about this fixed delay.
The result I got is fixed delay =600ps. (Kintex 7)
I cannt find any introduction in DS182 and UG471.
I need help, THX.
Teacher drjohnsmith
Re: A fixed 600ps delay IDELAY ?
there are a few others on the forums doing the same,
basicaly you need a counter,
but as it can't run at 10 Ghz, you interpolate
A few ways to do this, a quick sugestion to get you thinking,
If you had two counters running at say 500 MHz,
but one on the rising edge , one on the falling edge,
then if you grab both counters at once, you can work out to 1000 MHz resolution where you are.
Teacher drjohnsmith
The fixed delay is dependent upoon routing / layout , and is determined at implimentation time,
Hi Thanks for your answer.
Can I use IDELAY for a internal signal ,not for a physical PIN?
Teacher drjohnsmith
Nope. The Idelay block connects to IO pins at one end.
time to ask , what you trying to do ?
I want to implement a Delay Unit which could be adjusted dynamic. Up to 1 ms range , 0.1 ns step resolution.
Teacher drjohnsmith
回复: A fixed 600ps delay IDELAY ?
With regards to the delay when tap=0, please have a look at this answer.
https://www.xilinx.com/support/answers/42133.html
You can drive IDELAY with either IOB or FPGA logic. For internal signal, connect it to DATAIN input rather than IDATAIN, and set DELAY_SRC to DATAIN.
