Observer zhoushihua
A problem with ISE 14.5 map.
With Virtex6 LX760 device. I just use the MIG 3.9.2 generate a DDR3 memory controller with dqs implement as,
IOBUFDS_DIFF_OUT #
.IBUF_LOW_PWR (IBUF_LOW_PWR)
u_iobuf_dqs
.O (dqs_ibuf_p),
.OB (dqs_ibuf_n),
.IO (ddr_dqs_p),
.IOB (ddr_dqs_n),
.I (dqs_p_iodelay),
.TM (dqs_p_tq),
.TS (dqs_n_tq)
When I set -global_opt speed in map phase, it will get a wrong impelement. The IOBUFDS_DIFF_OUT will implement as a IOB on the p port and a IOBS on the n port. It will let the route fail.
When I set -global_opt off. It will impment as IOBM and IOBS.
But I need use -global_opt speed to improve timing of the other path. How could I do?
Community Manager
Community Manager
Re: A problem with ISE 14.5 map.
This is a known issue. The problem is that the connectivity in the actual IOB site is changing depending on if -global_opt is used or not.
when running -global_opt OFF (used by MIG) the IO site is of type "IOBM" and contains routes to the N pair (inside the IOB), but if -global_opt Area/Speed/Power is used the type changes to just "IOB" and does not contain any physical routes to the N pair. Hence there becomes an unroutable situation.
This can be worked around using "S" constraint.
NET "u_memc_ui_top/u_mem_intfc/phy_top0/u_phy_data_io/gen_dqs[0].u_phy_dqs_iob/u_iobuf_dqs/split_buf_net" S;
NET "u_memc_ui_top/u_mem_intfc/phy_top0/u_phy_data_io/gen_dqs[1].u_phy_dqs_iob/u_iobuf_dqs/split_buf_net" S;
I hope thsi helps.
Sikta
Community Manager
Community Manager
I hope thsi helps.
Sikta
Observer zhoushihua
Thank, I will try the work around.
BR
Shihua
Community Manager
Community Manager
Sure.Keep us posted.
Observer zhoushihua
Just try the constraint, it works.
BR
Shihua
