Observer moshiko
Abnormal program termination (11)
Using Vivado 2017.1 on AWS cloud.
I am running synthesis and in "Phase 3.9 DP Optimization" of placer it crashes with error message "Abnormal program termination".
It points to log file which shows the listing below.
Will appreciate your help to understand how to get over this issue.
-Moshe
# An unexpected error has occurred (11)
Stack:
/lib64/libc.so.6(+0x35270) [0x7fc484997270]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(SparseMapStorage::insert(unsigned int, unsigned int, double)+0xc3) [0x7fc457a4d853]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQPProblem::updateProblemWithEdgeDB(HAPLFQPProblem::EdgeDB const&, bool)+0x140) [0x7fc457a4d9b0]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQPProblemManager::buildB2BMatrix(bool)+0x35f) [0x7fc457a55e3f]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQPProblemManager::HAPLFQPProblemManager(HAPLFQP*, HAPLFPlaceInfo&, HDPoint<int> const&, bool, bool, bool, bool, bool, HAPLFQPProblemManager*, bool)+0x9a3) [0x7fc457a5bce3]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQP::makeProblemManager(bool, bool)+0xce) [0x7fc457a14cde]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQP::remakeProblemManagerIfNecessary(bool)+0x2b) [0x7fc457a14dab]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQP::solveAndSpread(bool, bool, int, int, bool)+0x1e) [0x7fc457a1c44e]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQP::doOneB2BSolve(bool, int, bool)+0x1f) [0x7fc457a1c4af]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::doOneB2BIteration(bool, bool, bool, bool)+0x7b) [0x7fc457a20c0b]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFSimPLFlow::solveWithB2BIters(bool)+0x119) [0x7fc457abfec9]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFSimPLFlow::solve()+0x207) [0x7fc457ac02e7]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFSimPLFlow::run()+0x936) [0x7fc457ad8f36]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::runSimPLFlow()+0x271) [0x7fc457a36c71]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_implflow.so(HAPLFFastPlace3::doOneSimPLRun()+0x7a) [0x7fc45b9ed62a]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_implflow.so(HAPLFFastPlace3::placeDetail3()+0x1d9) [0x7fc45ba097b9]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_implflow.so(HAPLFFastPlace3::doDetailPlacementBody(bool)+0x775) [0x7fc45ba0a9e5]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/librdi_implflow.so(+0xd98f2a) [0x7fc45ba0af2a]
/opt/Xilinx/SDx/2017.1.op/Vivado/lib/lnx64.o/libgomp.so.1(+0x15c66) [0x7fc47eba3c66]
/lib64/libpthread.so.0(+0x7e25) [0x7fc48474de25]
/lib64/libc.so.6(clone+0x6d) [0x7fc484a5a34d]
Re: Abnormal program termination (11)
Hi @moshiko,
If possible, please provide a testcase to regenerate this crash at our end so the community can provide the solution as earliest.
hemangd
Observer moshiko
The error does not reproduce on portion of the design, only when synthesizing the full design.
I cannot provide the design but can provide any detailed debug log per your request.
For now, I reverted the design work done on last couple of days and trying to proceed in different design directions, but this is a showstopper for me, so would appreciate your help.
-Moshe
Hi @moshiko,
Does this error occurs during Implementation or during synthesis ? Can you please share the Vivado.log file
If this error occurs at synthesis, Can you please try synthesizing the individual modules present under the top level and check on which module this error occurs.
Thanks & Regards,
A.Shameer
Hi @moshiko
Try to run with default implementation strategy and then check that you face the same issue or not.
hemangd
@moshiko
Can you please share the synthesis log file with us to understand which phase of synthesis is crashing?
Did you try using different hierarchy approach?
Anusheel
Observer moshiko
The crash occurs during implementation (Step 3.9 DP Optimization of placer).
I prefer to take this offline so that we can provide log files / other means to debug this on your side.
-Moshe
