Aurora Example Design debug issue
Hi all,
I am trying to debug the Aurara example design and I keep getting this message when I try to run the trigger on the iLA core
[Labtools 27-1395] Unable to arm ILA 'hw_ila_1'. The core clock is slow or no core clock connected for this ILA or the ILA core may not meet timing.
I can't find a working solution on the forum, can anyone help?
Hi @hmustafachico ,
Could you check the ila clock is active?  You can set the clock as ouput and check it by oscilloscope.
