araongao2015
Can FF with fanout more than 1 be put into laguna register?
In my design, there are some paths from FF in SLR0 (called tx_ff) to FF in SLR1 (rx_ff).
If the fanout of tx_ff is greater than 1, then can it be put into the laguna register?
If the fanout of rx_ff is greater than 1, then can it be put into the laguna register?
If the device is UltraScale, what's the answer?
If the device is UltraScalePlus, what's the answer?
syedz
@araongao2015
I don't think it is possible:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug949-vivado-design-methodology.pdf#page=274
--Syed
