LichengGuo-UCLA
Change physical cell equation of LUT
Hi everyone,
I'm trying to hack the post-routing checkpoints.
Specifically, I want to move a cell to a LUT that is configured as route-through.
Once I run "place_cell XXXX SLICE_X128Y277/A6LUT", I will get the complaint that "Cannot use A6 pin since it is in use"
Somehow that this LUT is empty, but the IS_USED property is marked True.
It is a way to reconfigure this LUT and let me do the replacement (followed by re-routing) ?
Thanks for your help!
driesd
Hi Licheng
This XXXX LUT, is this the route-through LUT?
Or are you trying to move another LUT to that location where there is currently a route-through LUT?
Route-through LUTs are required to reach certain other pins inside the SLICE like CARRY or FF.
I would recommend either to choose another location for your LUT or to move the CARRY or FF. You cannot put a LUT on a LUT already used as route-through.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
driesd
Hi Licheng
Best regards
Dries
LichengGuo-UCLA
Thanks for your explanation. So those route-through LUTs are determined after placement?
driesd
Yes, based on the placement of these registers/CARRY elements, a route-through LUT is used.
