Observer squaringcircle
[Common 17-161] Invalid option value '20.000 20.000' specified for 'value'.
Since I've done some minor changes to the clock source of a design, I'm getting more than 100 critical warnings.
Each critical warning is related to a FIFO constraint.
Looking into the FIFO xdc file, I'm getting errors for each "set_bus_skew".
Here's the complete error message for a single FIFO:
[Common 17-161] Invalid option value '20.000 20.000' specified for 'value'. ["sources_1/ip/ddr3_data_sync/ddr3_data_sync/ddr3_data_sync_clocks.xdc":63]
[Common 17-161] Invalid option value '20.000 20.000' specified for 'value'. ["sources_1/ip/ddr3_data_sync/ddr3_data_sync/ddr3_data_sync_clocks.xdc":66]
I've checked post-synthesis schematic, and all clock tree seems to be connected and valid.
I've reset & generated the output products for all FIFOs, but the issue still remains.
Did anyone face a similar issue already?
Any hint or guidance is highly appreciated.
Re: [Common 17-161] Invalid option value '20.000 20.000' specified for 'value'.
@squaringcircle
I have sent you email from ezmove where you can upload the project archive and send it back.
50.00000000000000000 36.87200164794921900 36.87200164794921900
The above value is incorrect. The return value skew_value should return on one number.
--Syed
Hi @squaringcircle
This message looks to be indicating incorrect command usage, or a constraints syntax error. Can the full text of the constraint be added?
Hi @marcb ,
Thanks for getting back on this topic.
Here's the complete constraint:
# Native FIFO Constraints #
set wr_clock [get_clocks -of_objects [get_ports wr_clk]]
set rd_clock [get_clocks -of_objects [get_ports rd_clk]]
set wr_clk_period [get_property PERIOD $wr_clock]
set rd_clk_period [get_property PERIOD $rd_clock]
set skew_value [expr {(($wr_clk_period < $rd_clk_period) ? $wr_clk_period : $rd_clk_period)} ]
# Set max delay on cross clock domain path for Block/Distributed RAM based FIFO
set_max_delay -from [get_cells inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*rd_pntr_gc_reg[*]] -to [get_cells inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*gsync_stage[1].wr_stg_inst/Q_reg_reg[*]] -datapath_only [get_property -min PERIOD $rd_clock]
set_bus_skew -from [get_cells inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*rd_pntr_gc_reg[*]] -to [get_cells inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*gsync_stage[1].wr_stg_inst/Q_reg_reg[*]] $skew_value
set_max_delay -from [get_cells inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*wr_pntr_gc_reg[*]] -to [get_cells inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*gsync_stage[1].rd_stg_inst/Q_reg_reg[*]] -datapath_only [get_property -min PERIOD $wr_clock]
set_bus_skew -from [get_cells inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*wr_pntr_gc_reg[*]] -to [get_cells inst_fifo_gen/gconvfifo.rf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*gsync_stage[1].rd_stg_inst/Q_reg_reg[*]] $skew_value
This constraint is auto generated by the Vivado FIFO Generator.
The critical warning during implementation points to the line of $skew_value - 2 errors per file / 1 per write & read clock.
If its helpful, I could also provide the entire IP.
Thank you very much for your support.
@squaringcircle
Try reset and regenerate the FIFO IP output products. The tool is getting incorrect value from constraints which is causing the issue.
--Syed
Hi @syedz ,
Thanks for the feedback.
I've already tried this for all IPs in the design - including FIFOs and the MMCM creating the FIFO clock, but no change in the results.
@squaringcircle
Since you mentioned that value is from set_bus_skew, Check whats the value returned for the following command:
Can you share the project archive?
--Syed
@syedz
Thanks for getting back.
This is the response I'm getting from TCL:
Do you need the entire project?
This is quite large - would need to upload it to an ftp or similar.
@squaringcircle
--Syed
The solution was to completely re-create the project from scratch - including FIFO ip cores.
Visitor yubex
Hi Guys,
unfortunately i have the same issue at the moment...
After synthesis there is the following critical warning:
[Common 17-161] Invalid option value '2.000 6.250' specified for 'value'. [".../rtl/fifos/stream_fifo_independend_clk/stream_fifo_independend_clk/stream_fifo_independend_clk_clocks.xdc":65]
which points to this constraint:
set_bus_skew -from [get_cells inst_fifo_gen/gaxis_fifo.gaxisf.axisf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*rd_pntr_gc_reg[*]] -to [get_cells inst_fifo_gen/gaxis_fifo.gaxisf.axisf/grf.rf/gntv_or_sync_fifo.gcx.clkx/*gsync_stage[1].wr_stg_inst/Q_reg_reg[*]] $skew_value
Is there any other way to resolve this, except re-create the project from scratch?
Guide avrumw
Guide
These constraint files are wrong... This is a known problem that has been fixed (like years ago)...
When you do
get_property PERIOD [get_clocks -of_objects <some_pin_net_or_cell>]
This works fine as long as there is only one clock on <some_pin_net_or_cell> - this returns a single number which is the period of the clock.
In fact, in general when you pass the get_property command a list of objects, it returns the property from every object in the list as a list of values.
In Vivado, a pin, net or cell can carry more than one clock. This can be done explicitly with a "create_clock -add" or "create_generated_clock -add" (although this is rarely the problem), or comes about naturally as a result of a clock multiplexer. If you have a clock MUX, with two inputs, and each input has a "create_clock" (or create_generated_clock) upstream of the clock MUX (as they should) then the output of the clock MUX (the O pin and anything downstream from it) carry both clocks. If this clock then reaches a module that uses the above command in a scoped XDC file, then the "get_clocks" command returns a list of two clocks instead of a single clock objects, and hence the get_property command returns a tuple {20.000 20.000} - this is not a legal input for an "expr" command or for the value of a set_max_delay - hence you get the error/warning.
To solve this problem, Xilinx added a new option to the "get_property" command - the "-min" option (or -max).
get_property -min PERIOD [get_clocks -of_objects <some_pin_net_or_cell>]
Instead of returning a list of property values, it always returns a single number, even if passed a list of objects to get the property of. In the case of the -min, the command returns the smallest value of the returned list (in this case, the shortest period of the clocks on this pin/net/cell)
This problem was discovered ages ago, and the get_property -min has been part of the tool for several years. In the intervening time, all Xilinx IP has been modified to use the -min option to avoid this problem. So you shouldn't be seeing the error/warning anymore. If you are, your IP is grossly out of date (since it hasn't migrated to using the new XDC files with the -min option).
Avrum
Visitor yubex
Great Answer!
Thanks for clearing that up Avrum.
You are right, i have an old Vivado Project 2016.4 running and i have a clock multiplexer in my design...
