Conflict in I/O Standard on KCU116 evaluation kit (XCKU5P FPGA chip)
Hello.
I'm using VIVADO and KCU116 evaluation kit (which contains Kintex UltraScale+ chip, xcku5p-ffvb676-2-e)
In the KCU116 Evaluation Board User Guide (UG1239) p29, it is indicated that
G12 Pin in the FPGA is connected to CLK_125MHZ_p and the I/O standard is LVDS (as mentioned in below figure).
However, in the VIVADO, when I set the I/O standard to LVDS, an error occurs like below figure.
From the KCU116 Evaluation Board User Guide (UG1239) p 29 G12 pin should be configured to LVDS I/O standard but in VIVADO,
G12 pin can't use the LVDS I/O standard as illustrated above. The 2 cases are conflicting.
Why is this happening?
Thanks for your help.
ps. When I changed the LVDS to LVDS_25, the error disappears. Should I use LVDS_25 instead?
Re: Conflict in I/O Standard on KCU116 evaluation kit (XCKU5P FPGA chip)
Hi @kimjaewon
To find more information on the conflict, there are a couple things that you can do.
1. Hover the mouse over the red LVDS to see if there is a specific message. Normally there are for I/O incompatabilities.
2. manually set the constraint "set_property IOSTANDARD LVDS [get_ports <>]", and then report_drc after updating. This should give a message relating the port in question.
3. The information regarding LVDS within the SelectIO Guide would normally clarify the issue as well.
http://www.xilinx.com/support/documentation/user_guides/ug571-ultrascale-selectio.pdf#page=126
Hi @kimjaewon
