Critical Warning during Implementation
I have not placed instance design_1_i/clk_wiz_1/inst/clkin1_ibufgds at U8 then also I am getting below Critical Warning. Can someone please help me with this?
I am using KC705 evaluation board featuring the XC7K325T-2FFG900C FPGA.
[Vivado 12-1411] Cannot set LOC property of ports, Could not legally place instance design_1_i/clk_wiz_1/inst/clkin1_ibufgds at U8 (IPAD_X1Y10) since it belongs to a shape containing instance pcie_refclk_clk_n. The shape requires relative placement between design_1_i/clk_wiz_1/inst/clkin1_ibufgds and pcie_refclk_clk_n that can not be honoured because it would result in an invalid location for pcie_refclk_clk_n. ["/home/shubhamn/KINTEX_fpga_ethernet/KINTEX_fpga_ethernet.srcs/sources_1/bd/design_1/ip/design_1_clk_wiz_1_0/design_1_clk_wiz_1_0_board.xdc":3]
Hi @shubhamn
Please share your design to investigate further. Since U8 package pin is specific to pcie_clk port, not sure why the critical warning comes when you have not placed the  instance design_1_i/clk_wiz_1/inst/clkin1_ibufgds on it.
Rohit
Rohit
Below I have attached the design_1_wrapper_opt.dcp file of my project.
My major doubt is why I am not able to find U8 pin while allocating package pins to pcie_clkref_clk port.
Hi @shubhamn
U8 is dedicated MGTREFCLK pin. You have to instantiate IBUFDS_GTE2 instead of IBUFGDS if you want to use it to drive clock to fabric logic.
Deepika.
Hi @vemulad
I have used D26 for pcie_refclk_clkp then also why I am getting the above error. I have not used U8.
When I opened the design checkpoint and exported the physical constraints, I noticed the following set_property commands.
set_property BOARD_PART_PIN pcie_mgt_clkp [get_ports pcie_refclk_clk_p]
set_property BOARD_PART_PIN pcie_mgt_clkn [get_ports pcie_refclk_clk_n]
This means the design top level ports pcie_refclk_clk_p/n automatically derive LOC and IOSTANDARD from board part pins pcie_mgt_clkp/n.
If you do
get_property LOC [get_board_part_pins pcie_mgt_clkp]
it returns "U8".
You need to remove the BOARD_PART_PIN setting if not necessary.
Hi @graces
How to remove the BOARD_PART_PIN setting ?
The properties look to be set via IP xdc file.
Is it the clocking wizard IP within a block design? Did you set board interface in IP customization?
You may want to re-visit the IP customization as the clock input is not used as GT pin.
