tsotnep2
[DRC 23-20] Rule violation (NSTD-1) unspecified I/O standard ethernet lite zynq
I'm using ZedBoard Zynq Evaluation and Development Kit (xc7z020clg484-1)
I want ethernet on baremetal application.
but i get the two error below when i add ethernet lite:
[DRC 23-20] Rule violation (UCIO-1) Unconstrained logical port
1. why do i get this error? should not be this data included in ethernet IP ? or i missed something somewhere?
2. is using those two commands safe? when they're not safe? p.s. it works but still: ref: http://www.xilinx.com/support/answers/56354.html
set_property SEVERITY {Warning} [get_drc_checks NSTD-1]
set_property SEVERITY {Warning} [get_drc_checks UCIO-1]
3. the link says LVCMOS18 and LVCMOS25 are the IO standards for 7 series. so they're practically about standard of operating voltage what does those letter mean? LVCMOS.
Unconstrained logical port means, i have to set the actual pin number ? on which pin this signal should be mapped?
Then for ethernet, I have to manually set them on the pins that are connected to ethernet port right? or i should hope if i ignore that(with command above) it will automatically do that?
thank you
tsotnep2
so i was super wrong in doing that.
i was thinking maybe zynq processing system has ethernet included, and that is correct. no need to add ethernet lite ip separately
balkris
check this ARs
Thanks and Regards
Balkrishan
muzaffer
you need to assign the top level signals ie MDIO_RTL_MDC etc. to pins of the FPGA in your XDC file using PACKAGE_PIN constraints and also set the respective IOSTANDARD constraints for these pins.
Making these errors into warning is not enough as they will prevent a bitfile to be generated.
tsotnep2
Hi, thank you very much for response
so i'm trying to set those constraints.
mdio_rtl_mdc,
mdio_rtl_mdio_io,
mii_rtl_txd[3:0],
mii_rtl_rxd[3:0],
mii_rtl_crs,
mii_rtl_rst_n,
mii_rtl_rx_clk,
mii_rtl_rx_dv,
mii_rtl_rx_er,
mii_rtl_tx_clk,
mii_rtl_tx_en,
i manually opened : open_runs impl_1
and tried setting them but got those errors:
set_property IOSTANDARD LVCMOS18 [get_ports {mdio_rtl_mdc}]
set_property PACKAGE_PIN D10 [get_ports {mdio_rtl_mdc}]
ERROR: [Vivado 12-1411] Cannot set LOC property of ports, Site location is not valid
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_txd[0]}]
set_property PACKAGE_PIN E9 [get_ports {mii_rtl_txd[0]}]
Could not legally place instance mii_rtl_txd_OBUF[0]_inst at E9 (IOPAD_X1Y94) since
it belongs to a shape containing instance design_1_i/axi_ethernetlite_0/U0/IOFFS_GEN[0].
TX_FF_I. The shape requires relative placement between mii_rtl_txd_OBUF[0]_inst and
design_1_i/axi_ethernetlite_0/U0/IOFFS_GEN[0].TX_FF_I that can not be honoured because it
would result in an invalid location for design_1_i/axi_ethernetlite_0/U0/IOFFS_GEN[0].TX_FF_I.
but usually i use this pre-bitstream tcl script:
#src of info : http://www.xilinx.com/support/answers/56354.html
set_property IOSTANDARD LVCMOS18 [get_ports {mdio_rtl_mdio_io}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_txd[1]}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_txd[2]}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_txd[3]}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_rxd[0]}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_rxd[1]}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_rxd[2]}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_rxd[3]}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_crs}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_rst_n}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_rx_clk}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_rx_dv}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_rx_er}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_tx_clk}]
set_property IOSTANDARD LVCMOS18 [get_ports {mii_rtl_tx_en}]
#src of info 1 : http://dl.dropbox.com/u/65113214/16-10-05_23%3A49%3A52_Selection.png
    #taken from page 20-21 : http://zedboard.org/sites/default/files/documentations/ZedBoard_HW_UG_v2_2.pdf
#set_property PACKAGE_PIN C12 [get_ports {mdio_rtl_mdio_io}]
set_property PACKAGE_PIN A7 [get_ports {mii_rtl_txd[1]}]
set_property PACKAGE_PIN E10 [get_ports {mii_rtl_txd[2]}]
set_property PACKAGE_PIN A8 [get_ports {mii_rtl_txd[3]}]
set_property PACKAGE_PIN E11 [get_ports {mii_rtl_rxd[0]}]
set_property PACKAGE_PIN B7 [get_ports {mii_rtl_rxd[1]}]
set_property PACKAGE_PIN F12 [get_ports {mii_rtl_rxd[2]}]
set_property PACKAGE_PIN A13 [get_ports {mii_rtl_rxd[3]}]
#set_property PACKAGE_PIN  [get_ports {mii_rtl_crs}]
#set_property PACKAGE_PIN  [get_ports {mii_rtl_rst_n}]
set_property PACKAGE_PIN A14 [get_ports {mii_rtl_rx_clk}]
#set_property PACKAGE_PIN  [get_ports {mii_rtl_rx_dv}]
#set_property PACKAGE_PIN  [get_ports {mii_rtl_rx_er}]
set_property PACKAGE_PIN D6 [get_ports {mii_rtl_tx_clk}]
#set_property PACKAGE_PIN  [get_ports {mii_rtl_tx_en}]
#disable warnings for those that had no pin locations specified in manual
same on vivado 2016.1
i think i might be making a simple mistake, i just want an ethernet working on baremetal...
where do i set IP address and etc? in software?
tsotnep2
