Newbie xiaotong12
[DRC 23-20] Rule violation (PLIDC-9) IDELAYCTRL DRC Checks...The REFCLK pin of a IDELAYCTRL instance should always be driven by clock buffer
 I use VIVADO2015.03 and Virtex-7 mig ddr3 IP. During implementation, the error message is as follow:
ERROR: [DRC 23-20] Rule violation (PLIDC-9) IDELAYCTRL DRC Checks - REFCLK pin of IDELAYCTRL instance 'i_mig_ddr_controller/u_mig_mig/u_iodelay_ctrl/u_idelayctrl_200' is driven by 'clk200Mhz_ibuf'{IBUFDS}. This will lead to unroutable situation. The REFCLK pin of a IDELAYCTRL instance should always be driven by clock buffer
The clk200Mhz_ibuf is the clock of ddr3. Its funout is 2 and Vivado does insert BUFG for it during retarget phase of opt_design. But the place_design step through out the DRC error and ask for clock buffer. Is there any solution to eliminate the error?
Re: [DRC 23-20] Rule violation (PLIDC-9) IDELAYCTRL DRC Checks...The REFCLK pin of a IDELAYCTRL instance should always be driven by clock buffer
@xiaotong12@shirley_yang,
Can you try to manually instantiate BUFG on clk200Mhz net in the RTL.
You can also try to use CLOCK_BUFFER_TYPE attribute on the clock clk200Mhz. Check page number 43 in below user guide:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug901-vivado-synthesis.pdf
--Syed
Observer shirley_yang
Is there any update info refer to this problem?
Thanks!
--Syed
Newbie xiaotong12
I remember we did try to manually insert BUFG in our code. You can try that. We changed a synthesis tool version (Protocompiler) now and seems there's no this issue.
Xiaotong
