[DRC 23-20] Rule violation (RTSTAT-3) Unplaced terminals on net
I need help understanding why my design is failing DRC checks during the write_bitstream command:
[DRC 23-20] Rule violation (RTSTAT-3) Unplaced terminals on net - 12 net(s) have unplaced terminals.
The problem bus(es) and/or net(s) are
ch0_gthrxn_in,
ch0_gthrxp_in,
ch1_gthrxn_in,
ch1_gthrxp_in,
example_wrapper_inst/xusgth_1v5_10g_raw32_lc2_inst/inst/gen_gtwizard_gthe3_top.xusgth_1v5_10g_raw32_lc2_gtwizard_gthe3_inst/gen_gtwizard_gthe3.gen_channel_container[26].gen_enabled_channel.gthe3_channel_wrapper_inst/channel_inst/gthtxn_out[0],
example_wrapper_inst/xusgth_1v5_10g_raw32_lc2_inst/inst/gen_gtwizard_gthe3_top.xusgth_1v5_10g_raw32_lc2_gtwizard_gthe3_inst/gen_gtwizard_gthe3.gen_channel_container[27].gen_enabled_channel.gthe3_channel_wrapper_inst/channel_inst/gthtxn_out[0],
example_wrapper_inst/xusgth_1v5_10g_raw32_lc2_inst/inst/gen_gtwizard_gthe3_top.xusgth_1v5_10g_raw32_lc2_gtwizard_gthe3_inst/gen_gtwizard_gthe3.gen_channel_container[26].gen_enabled_channel.gthe3_channel_wrapper_inst/channel_inst/gthtxp_out[0],
example_wrapper_inst/xusgth_1v5_10g_raw32_lc2_inst/inst/gen_gtwizard_gthe3_top.xusgth_1v5_10g_raw32_lc2_gtwizard_gthe3_inst/gen_gtwizard_gthe3.gen_channel_container[27].gen_enabled_channel.gthe3_channel_wrapper_inst/channel_inst/gthtxp_out[0],
mgtrefclk0_x1y2_n,
mgtrefclk0_x1y2_p,
mgtrefclk0_x1y3_n,
mgtrefclk0_x1y3_p.
The design is placed, routed and meets timing.I'm running Vivado 2015.2.
David
Thanks for the reply. Indeed the GTH pins are not being connected to the GTH transceiver logic. It's very strange.
After playing around with this I believe the issue is related to the process of automatically updating a GTH core generated in 2015.1 to 2015.2. I recreated the core in the 2015.2 wizard (rather than upgrading) and I didn't run into this problem.
Dave
@david.hoffman RSTAT-3 checks unrouted and partially routed nets
Check log for detailed information.
open implemented design and look for buses and nets listed in drc.
-Pratham
Dave
