Visitor stuartten
[DRC RTRES-2] Global clock nets are using local routing resources
I'm implementing a very simple PCIe test design on the KCU116 eval board using Vivado 2017.4.1. During bitstream generation I get a DRC error as follows:
[DRC RTRES-2] Global clock nets are using local routing resources: Global clock nets are using local routing resources. 1 net(s) have at least one node with COST_CODE_NAME equal to BOUNCEACROSS or INTENT_CODE_NAME equal to NODE_DOUBLE, NODE_HLONG, NODE_HQUAD, NODE_SINGLE, NODE_VLONG, or NODE_VQUAD. This situation occurs when a global clock net must enter a clock region where all global clock routing resources are occupied. Check the report from report_clock_utilization to determine which clock regions are traversed by the problem net and use floorplanning or other physical constraints to ensure a maximum of 24 global clock nets occupy each clock region. The problem net(s) are sysClock100.
Section 7 of the clock utilization report (attached) indicates that no local clock resources are being used. What does this DRC error mean and what might I have done to generate it?
Visitor stuartten
Re: [DRC RTRES-2] Global clock nets are using local routing resources
Hi @marcb.  I think I found the problem.  I had the wrong clock signal going into the .sys_clk input of the Xilinx PCIe IP block.  Rather than the .ODIV2 output of the same IBUFDS_GTE4 whose .O output is sourcing the .sys_clk_gt input, I was using a generic global clock.  This forced a routing violation since this clock is not a legal source for .sys_clk.
Thanks for your help.  I believe I'm past this issue now.
Stuart
Hi @stuartten. Was the report_clock_utilization command entered with a routed design? It looks as though sections 6 and 7 of the report are not populated, so it is possibly a post-opt_design netlist.
The RTRES-2 would mean that the router unexpectedly needs to use local resources to reach a particular load. The nodes listed are non-global
This might mean that the router had no other choice but this path, but would help to look at the path. The nodes from the DRC can be selected from the device view with the below command.
select_objects [get_nodes -filter {INTENT_CODE_NAME==NODE_DOUBLE ||  INTENT_CODE_NAME==NODE_HLONG || INTENT_CODE_NAME==NODE_HQUAD || INTENT_CODE_NAME==NODE_SINGLE || INTENT_CODE_NAME==NODE_VLONG || INTENT_CODE_NAME==NODE_VQUAD  } -of [get_nets   {net_name}]]
Visitor stuartten
Hi @marcb, thanks for the quick response. You were right in that the clock utilization report I sent was from the synthesized design. Attached, please find a new report generated from the routed design. While this latter report certainly has more information, it doesn't mean much to me. I don't see any clock regions in which resource utilization is anywhere near capacity.
BTW, the query you suggested was not fruitful. Here are the results:
WARNING: [Vivado 12-507] No nets matched 'net_name'.
WARNING: [Vivado 12-2683] No nodes matched 'get_nodes -filter {INTENT_CODE_NAME==NODE_DOUBLE || INTENT_CODE_NAME==NODE_HLONG || INTENT_CODE_NAME==NODE_HQUAD || INTENT_CODE_NAME==NODE_SINGLE || INTENT_CODE_NAME==NODE_VLONG || INTENT_CODE_NAME==NODE_VQUAD } -of [get_nets net_name]'
What now?
Hi @stuartten. Thanks for the updated repot. I did not see any indication that the global resources are oversubscribed.
Is the design checkpoint available to send? This would investigate the issue further. I would be looking to find what path, and what loads are involved. This might help to identify how to resolve the issue. pre-routing the net "route_design -net [get_nets <name>]" could avoid the issue.
Visitor stuartten
Stuart
@stuartten,
Thanks for the update! Glad to know that the issue is resolved. Can you please close this thread by marking your above post as "Accept as Solution"
--Syed
