yzaxin
ERROR : [Designutils 20-1448] Failed to read archive ......
The error is:
[Designutils 20-1448] Failed to read archive 'E:/Project/Vivado/EES326_50T_test_2015p4_v01/EES326_50T_test_2015p4_v01.runs/impl_2/.Xil/Vivado-8080-Johnson-PC/dcp/m4_fpga_top.incr': input stream error. The archive does not contain an expected string or is corrupted.
This error appears when i run implementation;
I use vivado 2015.2; i don't know the reason and how to solve it; please help me;Thanks
yashp
From the error message this looks like corrupt archive.
Can you please try to unarchive/unzip your project again and try to open?
Also please make sure that the location you are unzipping your project should have proper read/write permisssions.
Yash
syedz
@yzaxin,
Can you give us some more information? Are you trying to use dcp file and run place & route on it?
If possible can you try implementing the design in Vivado 2016.2?
--Syed
yashp
Yash
yzaxin
I dont have vivado 2016.2
This project was built with vivado 2015.4 and when i rebuilt the project with vivado 2015.2,the error appeared.
I found the folder "EES326_50T_test_2015p4_v01/EES326_50T_test_2015p4_v01.runs/impl_2/.Xil/" is empty, the archive "m4_fpga_top.incr" did not exist. So I want to know the effect of this file, and how to build it.
yzaxin
i have solved this problem, thanks
syedz
@yzaxin,
Can you please share the steps followed to resolve the issue. Was it due to corrput file or due to read/write permission?
It will help other users who might face similar error.
Syed
