ERROR:Place:1377 - Regional clock net
Hi all,
I am getting the below error, please let me know the solution.
Tool: ISE 14.6
Device: virtex 6
   "u_ddr3/u_memc_ui_top/u_mem_intfc/phy_top0/clk_rsync<0>" is not routable with
   loads locked in different clock regions such that it will be impossible for
   the source to be routed to all loads. See below for a list of sample locked
   components in each clock region. For more information on the clock region
   rules, please refer to the architecture user's guide. To debug your design
   with partially routed design, please allow mapper/placer to finish the
   execution (by setting environment variable XIL_PAR_DEBUG_IOCLKPLACER to 1).
Naveen G K
Re: ERROR:Place:1377 - Regional clock net
Hi @naveengk14,
At best a regional clock buffer (BUFR) can only reach loads in the same or vertically adjacent clock region. If the loads are constrained elsewhere you will see this error. To debug, set the variable and then examine the resulting unroutable NCD in FPGA Editor to determine which loads are causing the problem. Examine the constraints for those loads.
Nupur
Hi @naveengk14
Are you using MIG IP?
In case if you have modified the MIG IO pinout after MIG IP generation then use "verify UCF and update design" option in MIG and regenerate MIG RTL for new MIG UCF.
Deepika.
Hi @naveengk14
Did you try the suggestions from earlier posts?
Deepika.
hi,
    I have met the same question, but a little different. in the example design, I used the ucf which recommended by MIG and no error occured. but after i added  other user logic , this error occured. so ,what can i do?
Hi @liwengang. Since this is a new issue, can you enter a new post, and indicate what type of buffer is driving the loads in question?
