Observer yangf3
Error: Design cannot be automatically placed
I received a working design in schematics, and I translated it into verilog behavior models. The original design was implemented sucessfully. I used the same .ucf file but got an error with the new design.
ERROR:Place:207 - Due to SelectIO banking constraints, the IOBs in your design cannot be automatically placed.
346 signals are not completely routed.
WARNING:Par:100 - Design is not completely routed.
I used FPGA Editor to see all the unrouted nets. Many of them with names N# are not defined by me. I dont't know what they are, and there are too many nets to be routed manually. How can I solve this problem?
My ISE version is 8.1.03i. The target device is Spartan3 XC3S50. Thanks.
Message Edited by yangf3 on 02-04-2009 06:18 AM
Historian
Historian
Re: Error: Design cannot be automatically placed
yangf3 wrote:
Thanks for your reply. But I only used LVCMOS33, not a single LVCOMS25. The exactly same .ucf file works with the old design. Any other possible reasons? Thanks.
Are there any ports in the design that are NOT in the UCF?
I/Os default to LVCMOS25 unless otherwise changed in the UCF or in your code.
Do you have an differential pairs? There are a bunch of rules about diff pair placement.
-a
Historian
Historian
Forget the N# nets. Those are intermediates created by the synthesizer.
The real problem is explicitly stated in the error message. You probably have conflicting bank power-supply rails. Mixing ports with IOTYPE = LVCMOS33 and LVCMOS25 in the same bank will throw this error.
-a
Observer yangf3
Historian
Historian
-a
